Murata
  • Murata
Murata
Documents Murata PicoBK™︎ DC – DC Converters
Join Murata to participate - click to join for free!
  • Author Author: AyaT
  • Date Created: 3 Aug 2020 2:49 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 10:25 PM
  • Views 913 views
Ultra-Small DC-DC Converters – From 0.5A to 2.0A
MYR series are the PicoBKTm dc-dc converter family that integrate a coil and a control IC. The smallest form factor measures only 2.5mm x 2.0mm x 1.0mm. MYR series are all significantly smaller than discrete solutions. In most cases, these modules occupy less than half the footprint of the same solution implemented with discrete components.
Also, they achieve high efficiency, low noise and high heat dissipation. These modules are designed to be used with a 2.5V to 5.5V source such as a Li-ion battery. The input voltage of the MYRGC series is up to 36Vdc and can be used for battery applications to industrial applications. Typical efficiency of MYRGP at 5.0Vin / 3.3Vout is 93%. The control method can be selected fixed, PWM or PFM/PWM auto switch.
Series                      Product Description
MYRGC                     0.5A Inductor Built-in Step-down DC/DC Converter
MYRGP-W/B           1.0A Inductor Built-in Step-Down DC/DC Converters
MYRGM-W/B           1.5A Inductor Built-in Step-Down DC/DC Converters
MYRGM-X/C           2.0A Inductor Built-in Step-Down DC/DC Converters
Features:
1) Designed for battery powered applications
2) Very small SMT footprint
3) Typical efficiency 93%
4) Low Quiescent Current
5) Excellent EMI and Thermal Performance
Target Markets
- Hand held Battery Powered
- Wearables Battery Powered
- IOT
- UAVs
- Industrial Controls
- Automation
- Instrumentation
  • dc-dc convertor
  • murata
