NXP Semiconductors
  • NXP Semiconductors
NXP Semiconductors
Forum Residential Solar Power Inverters
Join NXP Semiconductors to participate - click to join for free!
  • Subscribers 40 subscribers
  • Views 353 views
PBrunner
PBrunner over 16 years ago
Residential scale grid-tie systems are the most common types of system today. They typically provide 3 to 10 kilowatts of output power and are not normally accompanied by a battery backup. Output AC power must be synchronized in phase, frequency, and voltage to the grid and have a low total harmonic distortion. String inverters, which control one or more strings of individual PV modules, are the most common types of inverters used for residential applications. The 56F83xx series of DSCs provide single chip control solutions for both MPPT and DC/AC conversion
http://www.freescale.com/files/graphic/block_diagram/G4523_APLSERS_TN.jpg
Additional Tools
Tools
Implement Efficient Solar Inverters Using Freescale Microcontrollers and Digital Signal Controllers
The efficient transformation of solar energy into electricity for home usage requires smart battery management and DC/AC voltage conversion, requiring electronic circuits to be precise, robust and interconnected.
Join us on this session to understand how low-power high-performance Freescale MCUs and DSCs can manage trivial tasks in solar inverter systems improving efficiency, reducing noise, and allowing system supervision among many other things
Energy Regeneration
When we talk about energy conservation, what are some of the things that come to mind? Maybe the responsible use of energy? A more efficient load or energy delivery systems? But what about reusing energy that has already delivered to a load and stored as kinetic energy. Some examples of these might include a rotating inertial load connected to a motor shaft or passenger vehicle decelerating. All of these systems, posses valuable energy which, until recently has simply being discarded in many cases.
With the current costs of energy, it is necessary to use and reuse energy as wisely as possible. In this presentation we will review and explore various topologies and control techniques to recapture load energy, in such a way that it can be used by another system, or stored for later use
Solar Power 101
This session will introduce how solar power works, its benefits and drawbacks. Learn what technologies are available today, their economics and how recent advancements can enable your next-generation product. Applications for the consumer market will be covered, including a demonstration of a battery charging system
Demo
Solar Power Inverter Reference Design Demo : Video - 2:37
This video is unavailable.
Recommended Devices
Freescale ProductsApplication UseSolution Advantages
   32/64-Bit Microcontrollers & Processors
  • High integration makes Freescale digital signal controllers an affordable and flexible solution for power conversion applications
  • The 56F82xx family of products offers precise, fast and powerful peripherals for a smoother, better power conversion
  • Precise PWM modules and fast conversion speed ADCs make the 56F8xxx family of products optimal for commercial solar energy systems
  • Freescale's digital signal controllers are supported by CodeWarrior and Processor Expert, simplifying project development and debugging
   MCF51CN128: Product Summary Page  Low-cost, low-power, high performance 32-bit devices with ethernet
MCF5225X: One-Stop-Shop Connectivity 32-bit MicrocontrollersHighly integrated devices with on-chip USB, ethernet, CAN and encryption functions
56F803X: Digital Signal Controller with CAN
Includes a CAN communications module for connecting independent solar energy conversion modules
56F824X_825X: Digital Signal ControllerHigh speed PWM with NanoEdge technology, ultra-fast ADC with embedded PGA and Intermodule Cross Bar for optimal operation
MC56F800x: MC56F8006 and MCF56F8002 Digital Signal Controllers
High control and performance for the
lowest cost
MC56F83xx
The 56F83xx family of products expand the memory capabilities up to 512Kb of internal flash and offers access external program and data memory
