NXP Semiconductors
  • NXP Semiconductors
NXP Semiconductors
Documents Looking for more 32-bit options? … Start here
Join NXP Semiconductors to participate - click to join for free!
  • Author Author: tech1
  • Date Created: 14 Aug 2009 2:54 PM Date Created
  • Last Updated Last Updated: 14 Aug 2009 3:40 PM
  • Views 528 views
NXP offers more in ARM: more products, more interfaces, more design tools, more know-how.image
More and more designers are choosing 32-bit ARM microcontrollers (MCUs) for their designs – allowing them to add functionality, enable anywhere / anytime connectivity save power and extend battery life.
NXP offers the industry's broadest range of ARM-based 32-bit MCUs and integrates vital technologies – including USB, LCD, Ethernet and motor control – that enhance embedded applications of all kinds.
If you are looking to experience more 32-bit MCU options, this is the place to start..
The widest choice of USB options
Our 32-bit ARM microcontrollers offer you all the latest USB technologies, including full- and high-speed USB 2.0 device, host and On-The-Go (OTG) functions. They support all four transfer types – control, interrupt, bulk and, especially, isochronous, which is required for streaming audio. You can also choose special features you won't find anywhere else, such as dedicated DMA, SoftConnectTm and GoodLinkTm, integrated transceivers and multiple ports.
In addition to our own complimentary USB packages, NXP partners with leading software companies to provide state-of-the-art USB firmware.
Unique low-cost LCD integration
Take your pick from the most advanced LCD-based 32-bit microcontrollers available today, with features that enhance performance while saving power. You get high bandwidth and constant refreshes, with less CPU involvement and better power efficiency. There's even an integrated touch screen interface, making it easy for you to add touch capabilities. Plus, as our ARM families use the same LCD architecture, you can reuse existing circuitry when moving your system to a next-generation ARM.
The highest bandwidth Ethernet
Look no further for your 32-bit Ethernet devices. Giving you peak performance – even when used in combination with USB – our full-featured 10/100 Ethernet MAC block improves throughput by using DMA hardware acceleration. Our solutions offer you all the functions specified in the IEEE 802.3 standard, as well as several added features that enhance efficiency. Additionally, software tools make your Ethernet design-in even easier, reducing the time it takes to implement complex protocols.
Motor control with performance to spare
Take advantage of today's smaller, more efficient motors with our 32-bit ARM microcontrollers with integrated features for motor control. They all provide basic control of universal, brushed DC and other single-phase motors, while for more complex requirements we offer sophisticated functions with processing performance to spare. And, because many functions require less than 1% of CPU load, you can create a system that does more while using less power.
www.nxp.com
Features & benefits:
USB options
  • 50+ options for ARM7, ARM9 and Cortex-M3
  • Complete USB functionality: device, host, OTG
  • Complete, fully-certified USB operation
  • Special features including dedicated DMA, SoftConnectTm and GoodLinkTm
  • Pin- and software-compatible options across NXP families
LCD integration
  • 24 bpp color space: STN and TFT colors
  • Up to 1024 x 768 pixels
  • Designed for low power, high performance applications
  • Larger cache size and internal RAM
  • Integrated touchscreen controller
  • Software-compatible across NXP families
Ethernet
  • 10/100 Ethernet MAC with multilayered bus structure
    o dual-bus architecture on ARM7 core
    o multi-layered bus matrix on ARM9 and Cortex-M3 cores
  • DMA hardware acceleration
  • High bandwidth ensures industry's fastest Ethernet performance
Motor control
  • Support for simple single-phase to complex three-phase motors
  • Dedicated motor-control PWMs dramatically reduce CPU load
    o up to 24 channels supporting dual-edge control and dead-band insertion
  • Quadrature Encoder Interface (QEI) for highest precision
  • General purpose PWMs for basic control (2 or 3 channels) and simple 3-phase motor control (6 channels)
  • Memories from 8 KB to 1 MB of flash, with flashless options
  • Richer feature set with extended MCU capacity
Product information table:
Order Code
Mftr’s Part No.
Product
Description
Back Order Not Allowed
1524621
LH75401N0Q100C0LH75401N0Q100C0
MCU ARM7, LCD CTRL, SMD, LQFP144
1524623
LH75411N0Q100C0LH75411N0Q100C0
1524625
LH79524N0F100A1LH79524N0F100A1
MCU ARM7, LCD CTRL, SMD, LFBGA-208
1524626
LH79525N0Q100A1LH79525N0Q100A1
MCU ARM7, LCD CTRL, SMD, LQFP176
1524627
LH7A400N0F076B5LH7A400N0F076B5
MCU ARM9, LCD CTRL, SMD, LFBGA-256
1524629
LH7A400N0G000B5LH7A400N0G000B5
MCU ARM9, LCD CTRL, SMD, BGA-256
C
1524632
LH7A404N0F000B3LH7A404N0F000B3
MCU ARM9, LCD CTRL, SMD, LFBGA-324
1294786
LPC2101FBD48LPC2101FBD48
MCU, ARM7, 8K FLASH, SMD
1524633
LPC2102FBD48LPC2102FBD48
MCU ARM7, FLASH, SMD, LQFP48
1294788
LPC2103FBD48LPC2103FBD48
MCU, ARM7, 16K FLASH, SMD
1528396
MCU, ARM7, 16K FLASH, WAFFLE125
1085364
LPC2104BBD48.151LPC2104BBD48.151
MCU, 32BIT, 128K FLASH, SMD
C
1528280
MCU, 32 BIT, 128K FLASH, WAFFLE125
1201340
LPC2105BBD48.151LPC2105BBD48.151
1528359
1085365
LPC2106BBD48.151LPC2106BBD48.151
1528281
1524634
LPC2106FHN48LPC2106FHN48
MCU, ARM7, FLASH, HVQFN-48
1524635
LPC2109FBD64LPC2109FBD64
MCU, ARM7, 64K FLASH, LQFP64
C
1169483
LPC2114FBD64,151LPC2114FBD64,151
MCU, ARM7, SMD
C
1169484
LPC2119FBD64,151LPC2119FBD64,151
MCU, ARM7, SMD
C
1528337
MCU, ARM7, WAFFLE80
C
1169485
LPC2131FBD64,151LPC2131FBD64,151
MCU, ARM7, SMD
C
1528338
MCU, ARM7, WAFFLE80
C
1169486
LPC2132FBD64,151LPC2132FBD64,151
MCU, ARM7, SMD
C
1528339
MCU, ARM7, WAFFLE80
C
1169487
LPC2134FBD64,151LPC2134FBD64,151
MCU, ARM7, SMD
C
1528340
MCU, ARM7, WAFFLE80
C
1169489
LPC2136FBD64,151LPC2136FBD64,151
MCU, ARM7, SMD
1528341
MCU, ARM7, WAFFLE80
C
1169491
LPC2138FBD64,151LPC2138FBD64,151
MCU, ARM7, SMD
C
1528342
MCU, ARM7, WAFFLE80
C
1524638
LPC2141FBD64LPC2141FBD64
MCU, ARM7, 32K FLASH, LQFP64
1294789
LPC2142FBD64LPC2142FBD64
MCU, ARM7, 64K FLASH, SMD
1528398
MCU, ARM7, 64K FLASH, WAFFLE80
1524639
LPC2144FBD64LPC2144FBD64
MCU, ARM7, 128K FLASH, LQFP64
1524640
LPC2146FBD64LPC2146FBD64
MCU, ARM7, 256K FLASH, LQFP64
1605539
LPC2148FBD64LPC2148FBD64
MCU, ARM7, 512K FLASH, 64LQFP
1169492
LPC2210FBD144,551LPC2210FBD144,551
MCU, ARM7, SMD
C
1169493
LPC2212FBD144,551LPC2212FBD144,551
MCU, ARM7, SMD
1169495
LPC2214FBD144,557LPC2214FBD144,557
MCU, ARM7, SMD
C
1294791
LPC2220FBD144LPC2220FBD144
MCU, ARM7, 64K RAM, SMD
1169496
LPC2220FBD144,551LPC2220FBD144,551
1169497
LPC2290FBD144,551LPC2290FBD144,551
MCU, ARM7, SMD
C
1169498
LPC2292FBD144,551LPC2292FBD144,551
MCU, ARM7, 256K FLASH, SMD
C
1564399
LPC2292FBD144/01LPC2292FBD144/01
MCU, ARM7, 256K FLASH, LQFP144
1690392
LPC2294HBD144/01,5LPC2294HBD144/01,5
MCU, ARM7, 144LQFP
1524643
LPC2364FBD100LPC2364FBD100
MCU, ARM7, 10/100, USB, CAN
1524644
LPC2366FBD100LPC2366FBD100
1524645
LPC2368FBD100LPC2368FBD100
1524646
LPC2378FBD144LPC2378FBD144
1524647
LPC2468FBD208LPC2468FBD208
MCU, ARM7, USB OTG, CAN, SMD
1524688
LPC2917FBD144LPC2917FBD144
MCU, ARM968, LQFP144
1524691
LPC2919FBD144LPC2919FBD144
1524648
LPC3180FEL320LPC3180FEL320
MCU, ARM9, SMD
  • at:npi
  • sp:nxp
  • date:1_06_09
