NXP Semiconductors
  • NXP Semiconductors
NXP Semiconductors
Documents Tech First Kit-Freescale-ADS512101DIST-MPU Dev Kit
Join NXP Semiconductors to participate - click to join for free!
  • Author Author: tech2
  • Date Created: 30 Oct 2009 11:10 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:18 AM
  • Views 1306 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The ADS512101 Advanced Development System is a mini-ITX form-factor reference and mother board based on Freescale’s MPC5121e microprocessor. The board will provide on-board DDR SDRAM, NOR FLASH, NAND FLASH, (2) 4 wire RS232 ports, 2 CAN ports, USB 2.0, 10/100 Ethernet, Audio in/out/mic, SATA and PATA drive support, PCI, Micro-SD, 24bpp graphics,all powered from a standard ATX or 5 Volt wall mount power supply.
The board can be integrated into any configuration required by the addition of optional peripherals. These would include items such as enclosures, displays, HDD and numerous other mini-ITX accessories.
Kit Contents
The ADS512101DIST Development Kit contains the hardware essentials you will need to use it. The items in the Development Kit and their use are as follows.
  • ADS512101
  • User Manual (on CD)
  • Schematic (on CD)
  • 5V, 15W Wall Mount Power Supply
  • Null Modem Cable
  • CodeWarrior (Windows & Linux)
  • Additional Freescale collateral material (on CD)
Key FeaturesBack to Top
  • Standard Mini-ITX Mainboard, 17cm x 17cm
  • Freescale Processor MPC5121e
  • DDR2 RAM module- capacity 128Mbyte to 2 Gbytes
  • JTAG and control CPLD
  • LVDS 24-bit (LCD) or CMOS (Rev3), XGA, HDMI video support
  • 10/100 Ethernet copper ,RS-232 and CAN port
  • USB A, B and OTG
  • NOR, NAND and backup FLASH
  • Local bus IO connector
  • Stereo Audio (AC97)
  • SATA/PATA (IDE), Micro-SD
  • PCI/mini-PCI (radio slots)
  • Power Save Hibernate, Power connectors for 5V external power supply or standard ATX power supply.
Ordering InformationBack to Top
Supplier
Part Number
Freescale
ADS512101DISTADS512101DIST
Associated Products
Supplier
Description
Part Number
MaximLAN Transceiver
MAX3050ASAMAX3050ASA
Atmel2-Wire Serial EEPROM
AT24C32C-SH-BAT24C32C-SH-B
CypressPCI and SDRAM Buffers
CY2305SXC-1CY2305SXC-1
NSProgrammable LVDS Transmitter
DS90C385AMT/NOPBDS90C385AMT/NOPB
IntersilRS-232RS-232 Transceivers
ICL3225ECAZICL3225ECAZ
Micrel10Base-T 100Base-TX Physical Layer Transceiver
KSZ8041NLKSZ8041NL
NSMulti-Channel Audio Codec
LM4550BVH/NOPBLM4550BVH/NOPB
Linear6A High Efficiency DC to DC uModule
LTM4602EV#PBFLTM4602EV#PBF
STSerial Access Real-Time Clock with Alarms
M41T62Q6FM41T62Q6F
MicrelDual-Channel Power Distribution Switch
MIC2026-1BMMIC2026-1BM
MicrelDual 2A LDO Regulator
MIC68220YML TRMIC68220YML TR
TIOperational Amplifier
OPA690IDG4OPA690IDG4
TI16-Bit Transceiver with 3-State Outputs
SN74LVCH16245AZQLRSN74LVCH16245AZQLR
STDual or Triple Ultra-Low Voltage Supervisors
STM6717SVWY6FSTM6717SVWY6F
Similar Products
SupplierDescriptionSupport DevicePart Number
FreescaleMPC512e Microprocessor Evaluation / DevelopmentMPC5121e
ADS512101ADS512101
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
MAX3050/3057±80V Fault-Protected, 2Mbps, Low Supply Current CAN Transceivers364KB
AT24C32CAT24C32C 2-Wire Serial EEPROM515KB
CY2305CY2305 and CY2309 as PCI and SDRAM Buffers136KB
CY 22392CY 22392 Three-PLL General Purpose FLASH Programmable Clock Generator348KB
DS90C385AMT/NOPBDS90C385AMT/NOPBDS90C385A +3.3V Programmable LVDS Transmitter 24-Bit Flat Panel Display Link-87.5MHZ648KB
EPM570F100AEPM570F100A Section I. MAX II Device Family Datasheet1.18MB
ICL3225EICL3225E ±15kV ESD Protected, +3V to +5.5V,1Microamp,1Mbps,RS-232 Transceivers with Enhanced Automatic Powerdown380KB
KSZ8041NLKSZ8041NL 10Base-T 100Base-TX Physical Layer Transceiver612KB
LM4550BVHLM4550BVH - AC 97 Rev 2.1 Multi-Channel Audio Codec with Stereo Headphone Amplifier, Sample Rate Conversion and National 3D Sound992KB
LTM4602EV#PBF.LTM4602EV#PBF.LTM4602EV 6A High Efficiency DC to DC uModule328KB
M41T62M41T62 Serial Access Real-Time Clock with Alarms672KB
MIC2026-1BMMIC2026-1BMMIC2026 Dual-Channel Power Distribution Switch180KB
MIC68220MIC68220 Dual 2A LDO Regulator1.19MB
MPC5121EMPC5121E datasheet1.24MB
OPA690OPA690 Wideband, Voltage Feedback Operational Amplifier With Disable412KB
SN74LVCH16245ASN74LVCH16245A 16-Bit Transceiver with 3-State Outputs156KB
STM6717STM6717 Dual or Triple Ultra-Low Voltage Supervisors with Push-Button Reset388KB
Application Notes
File Name
Size
3D Graphics on the ADS512101 Board Using OpenGL ES120KB
MPC5121e SDHC Controller164KB
NAND Flash Boot for the Freescale MPC5121e1.16MB
Porting Linux for the MPC5121e1.35MB
Practical Considerations for Working With Low-Frequency Oscillators140KB
Running a FIR Filter on the AXE Using the AXE 688KB
Understanding the Integrated Programmable Interrupt Controller152KB
ADS5121EUM : ADS5121e User Manual1.12MB
MPC5121EQRUG : MPC5121e Hardware Design Guide1.71MB
Hardware & Software
File Name
Size
ADS5121e_4.0_SCH464KB
Linux BSP for Freescale ADS512101246MB
  • ap:mpu
  • at:development_kit
  • sp:freescale
  • at:tech_first_kit
