NXP Semiconductors
  • NXP Semiconductors
NXP Semiconductors
Documents Tech First Kit-Freescale-RD3803MMA7660FC-Accelerometer-Dev Kit
Join NXP Semiconductors to participate - click to join for free!
  • Author Author: tech2
  • Date Created: 20 Nov 2009 9:20 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 2:22 AM
  • Views 992 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The RD3803MMA7660FCRD3803MMA7660FC is designed to provide the user with a complete out of the box experience to evaluate the MMA7660FC, a low power, 3-axis linear accelerometer with I2C digital output. An accelerometer daughter board plugs directly into the communication board for evaluation of the MMA7660 accelerometer and its functions. The accelerometer daughter board can be removed for customer prototyping and is also available to order separately as KIT3803MMA7660FC.KIT3803MMA7660FC..
The KIT3803MMA7660FC.KIT3803MMA7660FC. is an accelerometer daughterboard designed with all the accelerometer pins connected directly to a standard DIP socket for fast system prototyping and device evaluation within the user's application. This sensor daughterboard is also available in the RD3803MMA7660FCRD3803MMA7660FC development kit that includes the daughterboard along with the MCU communicator board.
Kit Contents
  • Communication board containing a Freescale MCU and USB interface which enables the communication with a PC
  • Accelerometer daughter board with MMA7660FC accelerometer
  • Graphical user interface (GUI) for demonstrating all integrated accelerometer features as well as software routines for specific applications
  • USB Connector
  • Sensor CD containing pertinent application notes, datasheets, software and sensor links
Key FeaturesBack to Top
  • Digital Output (I2C)
  • 3mm x 3mm x 0.9mm DFN Package
  • Low Power Current Consumption: Off Mode: 0.4 μA
  • Standby Mode: 2 μA, Active Mode: 47 μA at 1 ODR
  • Configurable Samples per Second from 1 to 120 samples a second.
  • Low Voltage Operation:
    • Analog Voltage: 2.4 V - 3.6 V
    • Digital Voltage: 1.71 V - 3.6 V
  • Auto-Wake/Sleep Feature for Low Power Consumption
  • Tilt Orientation Detection for Portrait/Landscape Capability
  • Gesture Detection Including Shake Detection and Tap Detection
  • Robust Design, High Shocks Survivability (10,000 g)
  • RoHS Compliant
  • Halogen Free
  • Environmentally Preferred Product
  • Low Cost
Ordering InformationBack to Top
Supplier
Part Number
Freescale
Associated Products
Supplier
Description
Part Number
FreescaleAn Accelerometer Daughterboard
KIT3803MMA7660FCKIT3803MMA7660FC
Freescale3-Axis Orientation/Motion Detection Sensor
MMA7660FCR1MMA7660FCR1
Freescale3-Axis Digital Output Acceleration Sensor
MMA7455LMMA7455L
Freescale3-Axis Analog Output Acceleration Sensor
MMA7331LMMA7331L
MMA7361LMMA7361L
MMA7341LMMA7341L
Analog DeviceSmall, Low Power, 3-Axis ±5 g Accelerometer
ADXL325BCPZADXL325BCPZ
Analog DeviceSmall, Low Power, 3-Axis ±16 g Accelerometer
ADXL326BCPZADXL326BCPZ
Analog DeviceSmall, Low Power, 3-Axis ±2 g Accelerometer
ADXL327BCPZADXL327BCPZ
Similar Products
SupplierDescriptionSupport DevicePart Number
Freescale
Output Accelerometer Evaluation Board
MMA745xL
KIT3468MMA7455LKIT3468MMA7455L
Freescale
3-Axis Digital Accelerometer Dev Kit
MMA7361L, MMA745xL
RD3172MMA7456LRD3172MMA7456L
Freescale
3-Axis Analog Accelerometer Evaluation Kits
MMA7341L
KIT3376MMA7341LKIT3376MMA7341L
Analog Device
Three-Axis Accelerometer Evaluation Board
ADXL335
EVAL-ADXL335ZEVAL-ADXL335Z
Analog Device
ADXL325BCPZ.ADXL325BCPZ.
EVAL-ADXL325ZEVAL-ADXL325Z
Analog Device
ADXL326BCPZ.ADXL326BCPZ.
EVAL-ADXL326ZEVAL-ADXL326Z
Analog Device
ADXL327BCPZ.ADXL327BCPZ.
EVAL-ADXL327ZEVAL-ADXL327Z
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
MMA7660FC3-Axis Orientation/Motion Detection Sensor797KB
MMA7455L3-Axis Digital Output Acceleration Sensor544KB
MA7331L3-Axis Analog Output Acceleration Sensor170KB
MMA7361L3-Axis Analog Output Acceleration Sensor170KB
MMA7341LThree Axis Low-g Micromachined Accelerometer170KB
Application Notes
File Name
Size
AN3837, Setting up the MMA7660FC for Orientation, Shake, Auto-Wake/Sleep and Tap Detection607KB
AN3839, MMA7660FC Board Mounting Guidelines454KB
AN3841, Performing Offset Calibration using the MMA7660FC177KB
AN3840, Setting up the MMA7660FC to do Orientation Detection349KB
AN3838, How to use the MMA7660FC with a Microcontroller to do Software Enhancements to Change Orientation Detection Trip...362KB
AN3803, RD3803MMA7660FC Evaluation Kit User’s Guide1819KB
RD3803MMA7660FC Quick Start Guide537KB
MMA7660FC Three-axis low g digital acceleration sensor347KB
MMA7660FC Accelerometer for Mobile Handsets355KB
Hardware & Software
File Name
Size
RD3803SCHEMATIC138KB
SCH-7672095KB
  • at:development_kit
  • ap:accelerometer
  • sp:freescale
  • at:tech_first_kit
