NXP Semiconductors
  • NXP Semiconductors
NXP Semiconductors
Documents Tech First Kit-Freescale-M52221DEMO-MCU-DVB
Join NXP Semiconductors to participate - click to join for free!
  • Author Author: tech4
  • Date Created: 24 Nov 2009 12:50 PM Date Created
  • Last Updated Last Updated: 27 May 2012 12:18 AM
  • Views 611 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The M52221DEMO is a low-cost development board for Freescale's MCF52221 ColdFire microcontroller.  Application development is quick and easy with the included DB9 serial cable, integrated BDM, and USB cable.  A 128 MB flash-drive and 6-in-1 USB cable provide support for the integrated USB PHY.  CodeWarrior Development Tools provide application develop-ment and debug support.  The integrated BDM allows easy application development and de-bugging.  An optional BDM port compatible with standard ColdFire BDM/JTAG interface cables and hosting software is also provided but not installed.
The target MCU features an on-board USB On-the-Go (OTG) physical layer (Phy).  The OTG Phy may be configured for either Host or Peripheral mode depending on the target application.
Kit Contents
  • MCF5222x  CPU 80 LQFP
  • 128 MB flash-drive
  • Integrated BDM
  • M52221DEMO User's Manual
  • DB9 Serial Cable
  • 6-in-1 USB Cable
  • Ethernet Cable
  • CodeWarrior Development Studio CD
Key FeaturesBack to Top
  • MCF52221 CPU
    • 80 LQFP
    • 128 Byte Flash
    • 16K Byte Ram
    • USB On-The-Go (OTG) Phy
    • 4ch, DMA Controller w/ Timers
    • 2ea. Programmable Interrupt Timer
    • 4 GPT Timers
    • 8ch, 12b ADC
    • UART Serial Ports with DMA capability
    • QSPI and IIC Ports
    • 3.3V operation
  • Integrated USB BDM
  • 48 MHz XTAL
  • 40 pin I/O port
  • miniUSB Port
  • BDM / JTAG Port (not installed)
  • RS-232RS-232 Serial Port w/ DB9-S Connector
  • ON/OFF Power Switch w/ LED indicator
  • RESET switch w/ indicator
  • Power Input Selection Jumper
  • User Features:
    • 3-axis Accelerometer
    • 4 User LED’s w/ enable
    • 2 User Push Switches
    • 5k ohm POT w/ enable
  • Option Jumpers:
  • Connectors
    • RJ-45 Ethernet Connector
    • Type B USB connector
    • DB9 Serial Connector
    • 2.0mm Barrel Power Input
    • 2pos, screw type, terminal block
Ordering InformationBack to Top
Supplier
Part Number
Freescale
M52211DEMOM52211DEMO
Freescale
M52211DEMO.M52211DEMO.
Associated Products
Supplier
Description
Part Number
Freescale
32-Bit Microcontroller IC
MCF52221CAF80MCF52221CAF80
Freescale
MCF52221CAE66MCF52221CAE66
SPC Technology
USB 2.0 Cable Assembly
SPC4800SPC4800
SPC Technology
Shielded Serial Cable Assembly
SPC19944SPC19944
Freescale
Software, suite licence, c/w, standard
CWA-STANDARD-NCWA-STANDARD-N
Freescale
In-Circuit Emulator, Debugger and Programmer for HCS08, HC(S)12(X), RS08, and ColdFire V1
USBMULTILINKBDMEUSBMULTILINKBDME
INTERSIL
RS232 Transceiver, SSOP20
ICL3225ECAZICL3225ECAZ
Freescale
Acceleration Sensor IC
MMA7260QTMMA7260QT
NS
Low Dropout Regulator
LM2937ES-3.3/NOPBLM2937ES-3.3/NOPB
Similar Products
SupplierDescriptionSupport DevicePart Number
Freescale
M52211EVB board
MCF52211
M52211EVBM52211EVB
Freescale
M52223EVB board
M52223
M52223EVBM52223EVB
Freescale
M52223EVB board
M52223
M52223EVBM52223EVB
Freescale
M52210 DEMO board
MCF52210
M52210DEMOM52210DEMO
Freescale
M52211 DEMO board
MCF52210
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
MMA7260QT
MMA7260QT, ±1.5g - 6g Three Axis Low-g Micromachined Accelerometer
194KB
MCF5221X
MCF5221X: 32-Bit Microcontroller with USB On-The-Go
1.2MB
ADM869L
High-Side P-Channel Switch with Current Limit and Thermal Shutdown - Analog Devices
124KB
ICL3225
RS-232 Transceivers with Enhanced Automatic Powerdown
462KB
LM2937
500 mA Low Dropout Regulator
309KB
Application Notes
File Name
Size
M5211DEMO User Guide
345KB
AN3523 Advanced CMX_USB_Stack Applications
616KB
M52210DEMO Quick Start Guide
27KB
MCF52211 Evaluation Board
MCF5221X_CWEXAMPLES
Hardware & Software
File Name
Size
M52210DEMO Schematics
228KB
Evaluation: CodeWarrior for ColdFire Architectures
301MB
CodeWarrior for ColdFire v7.1.2 Patch
162MB
301.6MB
161.9MB
M52210DEMO Software
380KB
ColdFire Flash Programmer
5MB
  • at:dvb
  • sp:freescale
  • ap:mcu
  • at:tech_first_kit
