NXP Semiconductors
  • NXP Semiconductors
NXP Semiconductors
Documents Tech First Kit-Freescale-MPC8360E-RDK-MPU-Dev Kit
Join NXP Semiconductors to participate - click to join for free!
  • Author Author: tech2
  • Date Created: 10 Dec 2009 4:12 AM Date Created
  • Last Updated Last Updated: 27 Oct 2013 2:22 AM
  • Views 1539 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The Reference Design Kit (MPC8360E-RDK ) highlights the capabilities of the MPC83xx PowerQUICCRegistered processors for applications that require high-performance connectivity and determinism. The platform supports graphics and touch screen capability in addition to popular interfaces such as Ethernet, 64-bit PCI controllers, UARTS, integrated security engine, USB, SPI, I2C, and (GPIO) pins. The platform ships with a LinuxRegistered board support package, bootloader, production-ready protocols for evaluation, and is supported by Freescale CodeWarriorRegistered tools, Wind River Linux and VxWorksRegistered and Green Hills INTEGRITYRegistered/velOSityTm. The protocols include: EtherNet/IPTm and DeviceNetTm which is licensable from Real Time Automation, ETHERNET Powerlink and IEEERegistered 1588 which are licensable from IXXAT. Additional protocols are under development for this platform. This platform utilizes the industry-standard COM-Express module for the MPC8360 microprocessor which allows for future MPC83xx modules to be offered for this development environment.
Kit Contents
  • Type 3 module
  • Supports full MPC83xx PowerQUICC processor family
  • 256 MB of DDR2 SDRAM
  • 8 MB Boot NOR Flash
  • 2x 10/100/1000 Mbps Ethernet
  • 2x 10/100 fast Ethernet
  • Graphics and touch screen capable
  • 4x full functional UART
  • 32-bit PCI connection
  • 1x SPI
  • 1x I2C
  • 4 port USB HUB
  • 8 pins General Purpose Input/Output
  • 2 x PCI ExpressRegistered (x1 type)
  • 1 x PCI slots (32 bit / 66 MHz or 33 MHz)
  • Common I/O routed to back panel
    • 4 USB 2.0
    • 4 Ethernet
    • 2 RS485
    • 2 RS232
    • 4 SATA
  • Wireless connectivity through 1x mini-PCI
    • 802.11 or ZigBee TechnologyRegistered
Key FeaturesBack to Top
  • Platform/HW
    • Carrier Board FlexATX
    • MPC8360E COM Express module
    • Power Supply
    • Null-modem serial cable
  • Protocols – Optimized Binaries **
    • EtherNet/IPTm (RTA)
    • DeviceNetTm (RTA)
    • Ethernet Powerlink (IXXAT)
    • IEEERegistered 1588 (IXXAT)
  • Tools
    • CodeWarriorRegistered IDE & USB TAP for Debug
    • LinuxRegistered BSP & Optimized device Drivers *
    • U-Boot Bootloader installed on resident flash *
    • Wind River LinuxRegistered and VxWorks **
    • Green Hills INTEGRITYRegistered/velOSityTm and MULTIRegistered **
  • Design Files – downloadable for COM Express module only
    • PDF of Schematics, Layout
    • BOM
  • Documentation
    • Quick Start Guide
    • Users Guide **
Ordering InformationBack to Top
Supplier
Part Number
Freescale
MPC8360E-RDKMPC8360E-RDK
Freescale
Associated Products
Supplier
Description
Part Number
SPC Technology
USB 2.0 Cable Assembly
SPC4800SPC4800
SPC Technology
Shielded Serial Cable Assembly
SPC19944SPC19944
Freescale
Software, suite licence, c/w, standard
CWA-STANDARD-NCWA-STANDARD-N
Freescale
USB ColdFire Multlink
USBMLCFUSBMLCF
Freescale
Embedded Networking Processor IC
MPC8360EVVAJDGAMPC8360EVVAJDGA
Freescale
MPC8360EVVAGDGAMPC8360EVVAGDGA
Freescale
MPC8360EVVALFHAMPC8360EVVALFHA
TI
RS-232RS-232 Transceiver IC
MAX3232CDBE4MAX3232CDBE4
Similar Products
SupplierDescriptionSupport DevicePart Number
Freescale
MPC8313E Reference Design Kit
MPC8313E
MPC8313E-RDBMPC8313E-RDB
Freescale
MPC8313E
Freescale
MPC8349EVVAGDB.MPC8349EVVAGDB. Hardware / Software - Reference Design Kit
MPC8349EVVAGDB.MPC8349EVVAGDB., MPC8321EVRAFDC.MPC8321EVRAFDC., MPC8323
MPC8349E-MITX-GPMPC8349E-MITX-GP
Freescale
MPC8315E-RDBAMPC8315E-RDBA Hardware / Software - Reference Design Kit
MPC8315E-RDBMPC8315E-RDB
Freescale
MPC8323E Hardware / Software - Reference Design Kit
MPC8323E
MPC8323E-RDBMPC8323E-RDB
Analogue& Micro
MPC8347 Development Kit
MPC8347
ASP 8347ASP 8347
Document ListBack to Top
Data Sheet
Part NumberDescriptionSize
MPC8360
MPC8360E/MPC8358E PowerQUICC II Pro Processor Revision 2.x TBGA Silicon Hardware Specifications
1.23MB
HIN202EIBNZHIN202EIBNZ
+5V Powered RS-232 Transmitters/Receivers with 0.1Microfarad External Capacitors
493KB
DP83848
DP83848VYB PHYTERRegistered - Extended Temperature Single Port 10/100 Mb/s Ethernet Physical Layer Transceiver
148KB
USB3300
High speed USB host or device phy
345KB
MAX3232
609KB
Application Notes
File Name
Size
MPC8360EMDSUM : MPC8360 Modular Development System Processor Board User's Manual
3.51MB
AN2859SW_FPM Frequency Pulse Measurement (FPM) eTPU Function API
2KB
AN2858SW_PPA Pulse Period Accumulate (PPA) eTPU Function API
2KB
AN2583 Programming the PowerQUICC III/PowerQUICC II Pro DDR SDRAM Controller
572KB
AN3645 SEC 2/3x Descriptor Programmer’s Guide
1MB
AN3939 DDR Interleaving for PowerQUICCRegistered and QorIQTm Processors
590KB
AN3538 Enabling and Checking DDR ECC on PowerQUICC II
449KB
2KB
MPC8360EMDSUMAD : MPC8360 Modular Development System Processor Board Hardware Getting Started Guide
1.04MB
AN3097 : MPC8360/MPC8358E PowerQUICC Design Checklist
282KB
MPC8360EAMDSUM : MPC8360EA Modular Development System Processor Board User's Manual
3.67MB
AN3830 Hardware Debugging Using the CodeWarrior IDE
1.57MB
AN3880 Ethernet Extended Frame Filtering
553KB
AN2755: SEC 2.0 Descriptor Programmer's Guide
806KB
AN2915 Design Migration from the PowerQUICC II Family to the PowerQUICC II Pro Family
605KB
AN3373 PowerQUICC II Pro (MPC83xx) PCI Agent Initialization
449KB
AN3097 MPC8360/MPC8358E PowerQUICC Design Checklist
281KB
AN3536 Enhanced Serial Interface Mapping: 16 E1/T1 QUICC EngineTm Solution for TDM Connectivity
525KB
AN2129 Instruction and Data Cache Locking on the e300 Processor Core
474KB
Hardware & Software
File Name
Size
Service Pack 1 for 837x Rev.2.1 for CodeWarrior Development Studio for NetComm Power Architecture...
25.5MB
Evaluation: CodeWarrior for Power Architecture, Linux Applications Edtn (Linux)
420MB
Evaluation: CodeWarrior for Power Architecture, Professional Edtn (Windows)
467MB
Code Warrior for Power Architecture - v8.7.1 Patch (Linux)
52MB
Code Warrior for Power Architecture - v8.7.1 Patch (Windows)
25MB
Linux BSP for Freescale MPC8360EA-MDS-PB
810MB
CodeWarrior Ethernet TAP RoHS Debug Probe Update (Windows)
14.7MB
CodeWarrior Ethernet TAP RoHS Debug Probe Update (Linux)
14.7MB
U-Boot for MPC8560 on MSC8144ADS
91.4MB
Netcomm Device Drivers Package includes Rev 3.0 executable
431MB
SEC 2.x and SEC 3.x Security Core Device Driver Package This archive contains the initial issue
590KB
UPM Tool for PowerQUICC II Pro and PowerQUICC III Processors
2.7MB
FreeMASTER Communication Driver
4.3MB
SEC2.x Security Core Device Driver 85xx/83xx SEC 2.x Device Drivers
75KB
SEC2.x Security Core Driver Examples and Test Suite
151KB
SEC2XSWUG Security Engine 2.x Reference Device Driver User's Guide: For SEC2.x Device
805KB
MPC8360EA Boundary Scan Description Language File (for revision 2.1 silicon)
83KB
MPC8360E Boundary Scan Description Language File
31KB
Slow Protocols RAM Package This microcode RAM package enables the UCC slow protocols: UART
503KB
RAM Microcode Patches for PowerQUICC II Pro Family QE Errata Microcode patches for QUICC Engine
258KB
MPC8360E Orcad Symbol File
64KB
  • ap:mpu
  • at:development_kit
  • sp:freescale
  • at:tech_first_kit
