NXP Semiconductors
  • NXP Semiconductors
NXP Semiconductors
Documents Tech First Kit-Freescale-M52210DEMO-MCU-Demo kit
Join NXP Semiconductors to participate - click to join for free!
  • Author Author: tech5
  • Date Created: 19 Jan 2010 4:05 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:18 AM
  • Views 1460 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The M52210DEMO is a low-cost development board for the Freescale MCF52210 ColdFire microcontroller.
Application development is quick and easy with the included DB9 serial cable, integrated BDM, and USB cable. A 128 MB flash-drive and 6-in-1 USB cable provide support for the integrated USB PHY.
CodeWarrior Development Tools provide application development and debug support. The integrated BDM allows easy application development and debugging. An optional BDM port compatible with standard ColdFire BDM / JTAG interface cables and hosting software is also provided but not installed.
Kit Contents
  • MCF52210  CPU 80 LQFP
  • 128 MB flash-drive
  • Integrated BDM
  • M52221DEMO User's Manual
  • DB9 Serial Cable
  • 6-in-1 USB Cable
  • Ethernet Cable
  • CodeWarrior Development Studio CD
Key FeaturesBack to Top
  • MCF52210 microcontroller, 80 LQFP
  • Integrated USB BDM
  • Super-Cap Backup for VSTBY (not available on Rev A)
  • 48 MHz XTAL
  • 40 pin I/O port
  • MiniUSB Port
  • BDM / JTAG Port (not installed)
  • ON/OFF Power Switch w/ LED indicator
  • RESET switch w/ indicator
  • Power Input Selection Jumper
    • Power Input from USB BDM
    • Power input from miniUSB
    • Power Input from on-board regulator
    • Power Input from terminal block
    • Power from connector J1
  • User Features
    • 3-axis Accelerometer
    • 4 User LED’s w/ enable
    • 2 User Push Switches
    • 5k ohm POT w/ enable
  • Connectors
    • RJ-45 Ethernet Connector
    • Type B USB connector
    • DB9 Serial Connector
    • 2.0mm Barrel Power Input
    • 2pos, screw type, terminal block
Ordering InformationBack to Top
Supplier
Part Number
Freescale
M52210DEMOM52210DEMO
Freescale
M52210DEMO
Associated Products
Supplier
Description
Part Number
Freescale
32-Bit Microcontroller IC
MCF52210CAE66MCF52210CAE66
Freescale
MCF52210CEP66MCF52210CEP66
SPC Technology
USB 2.0 Cable Assembly
SPC4800SPC4800
SPC Technology
Shielded Serial Cable Assembly
SPC19944SPC19944
Freescale
Software, suite licence, c/w, standard
CWA-STANDARD-NCWA-STANDARD-N
Freescale
In-Circuit Emulator, Debugger and Programmer for HCS08, HC(S)12(X), RS08, and ColdFire V1
USBMULTILINKBDMEUSBMULTILINKBDME
INTERSIL
RS232 Transceiver, SSOP20
ICL3225ECAZICL3225ECAZ
Freescale
Acceleration Sensor IC
MMA7260QTMMA7260QT
National Semiconductor
Low Dropout Regulator
LM2937ES-3.3/NOPBLM2937ES-3.3/NOPB
Similar Products
SupplierDescriptionSupport DevicePart Number
Freescale
M52211EVB board
MCF52211
M52211EVBM52211EVB
Freescale
M52223EVB board
M52223
M52223EVBM52223EVB
Freescale
M52223EVB board
M52223
M52223EVB
Freescale
M52211DEMO board
MCF52211
M52211DEMOM52211DEMO
Freescale
M52211DEMO board
MCF52211
M52211DEMO
Document ListBack to Top
Datasheet
Part Number
Description
Size
MMA7260QT
MMA7260QT, ±1.5g - 6g Three Axis Low-g Micromachined Accelerometer
194KB
MCF5221X
MCF5221X: 32-Bit Microcontroller with USB On-The-Go
1.2MB
ADM869L
High-Side P-Channel Switch with Current Limit and Thermal Shutdown - Analog Devices
124KB
ICL3225
RS-232 Transceivers with Enhanced Automatic Powerdown
462KB
LM2937
500 mA Low Dropout Regulator
309KB
Application Notes
File Name
Size
M5211DEMO User Guide
345KB
AN3523 Advanced CMX_USB_Stack Applications
616KB
M52210DEMO Quick Start Guide
27KB
AN3750:Using a USB Device with ColdFireRegistered OTG Module MCF522xx and a PC
227KB
MCF52211 Evaluation Board
616KB
Hardware & Software
File Name
Size
M52210DEMO Schematics
228KB
Evaluation: CodeWarrior for ColdFire Architectures
301MB
CodeWarrior for ColdFire v7.1.2 Patch
162MB
301.6MB
161.9MB
M52210DEMO Software
380KB
ColdFire Flash Programmer
5MB
  • at:demo_kit
  • sp:freescale
  • ap:mcu
  • at:tech_first_kit
    hi, i want to know what other software (besides "proghcs08") I can use to read and write processors from HCS08 family using
    USBMULTILINKBDME  (Farnell pn  1165943).
    many thanks!
