NXP Semiconductors
  • NXP Semiconductors
NXP Semiconductors
Documents Tech First Kit-Freescale-MPC5566EVB-MCU-Demo Kit
Join NXP Semiconductors to participate - click to join for free!
  • Author Author: tech5
  • Date Created: 19 Jan 2010 7:03 AM Date Created
  • Last Updated Last Updated: 27 May 2012 12:18 AM
  • Views 740 views
  • Overview
  • Kit Contents
  • Key Features
  • Ordering Information
Overview
The MPC55xxEVB Evaluation Kits include everything necessary to begin development with the MPC55xx family of microcontrollers. A comprehensive set of hardware and software development tool options are available including a free a flash programmer, initialization tools, and assembly level debug tool.
Kit Contents
  • Tools Include:
    • USB POWERPC NEXUS MULTILINK
  • Compiler Only
    • CodeWarrior (Demo Software)
  • Full IDE (Demo Software Only)
    • Green Hills
    • iSYSTEM (GNU other compilers)
    • P&E Micro (GNU compiler + free 64k debugger)
    • Lauterbach
    • Ashling (GNU compiler)
  • Initialization Software
    • Treck Ethernet Stack (Demo Software)
Key FeaturesBack to Top
  • Breadboard area, access to all signals
  • Nexus Connectors (MICTOR and 14-pin Berg). Footprint for Robust Connector
  • 32-channel eTPU connector
  • 1 CAN with PHY (Auto Temp Qualified)
  • 1 LIN Transceiver with PHY
  • 1 RS-232RS-232 Transceiver with PHY
  • 8 LED
  • 4 push buttons – 1 with hardware debounce, 8 SPST switches
  • 2 Potentiometers
  • 1 Audio Speaker with amplifier
  • UNI-3 Motor Interface connector plus sensor connector
  • MPC5554EVB & MPC5567EVBEMPC5567EVBE - 128Kx32 external SRAM
  • MPC5553EVB & MPC5534EVB - 256Kx16 external SRAM
  • MPC5553EVB - 10/100 Ethernet with PHY (National Semiconductor's PHY, DP83848YB, available in -40 to 125°C)
  • MPC5567EVBEMPC5567EVBE - Connectors and Transceivers for dual-channel FlexRay
  • MPC5566EVB.MPC5566EVB. - Has the same features as the MPC5553 EVB and the same schematics
    Ordering InformationBack to Top
    Supplier
    Part Number
    Freescale
    MPC5566EVBMPC5566EVB
    Freescale
    MPC5566EVB
    Associated Products
    Supplier
    Description
    Part Number
    SPC Technology
    USB 2.0 Cable Assembly
    SPC4800SPC4800
    SPC Technology
    Shielded Serial Cable Assembly
    MSPC19944MSPC19944
    Freescale
    Software, suite licence, c/w, standard
    CWA-STANDARD-NCWA-STANDARD-N
    Freescale
    USB ColdFire Multlink
    USBMLCFUSBMLCF
    Freescale
    32-bit PowerPC Microcontrollers
    MPC5566MVR132
    Texas Instruments
    Low-Voltage 10-Bit FET Bus Switch
    SN74CBTLV3861DWSN74CBTLV3861DW
    Texas Instruments
    Audio Power Amplifier IC
    TPA4861DRTPA4861DR
    Texas Instruments
    TPA4861DTPA4861D
    Intersil
    RS-232RS-232 Transmitters/Receivers
    HIN202CBZHIN202CBZ
    Intersil
    HIN202ECBNZHIN202ECBNZ
    Texas Instruments
    Quad buffer/line driver 3-state
    SN74LV125APWSN74LV125APW
    Freescale
    Local Area Network (LIN) Enhanced Physical Interface with Selectable Slew Rate
    MC33661D
    Texas Instruments
    Switch Logic IC
    SN74CBT16211ADLSN74CBT16211ADL
    Ethernet Transceiver
    DP83848IVV/NOPBDP83848IVV/NOPB
    Tiny CMOS Comparator
    LMC7221AIM/NOPBLMC7221AIM/NOPB
    Texas Instruments
    Quadruple 2-Input Exclusive-OR Gates
    SN74AC86DSN74AC86D
    Fairchild
    TinyLogic UHS 2-Input AND Gate
    NC7SZ08P5NC7SZ08P5
    Similar Products
    SupplierDescriptionSupport DevicePart Number
    Freescale
    MPC55xx Evaluation Board
    MPC5534, MPC5553, MPC5554MZP132MPC5554MZP132
    MPC5534EVBE
    Freescale
    MPC5534EVBE
    Freescale
    MPC5534, MPC5553,MPC5554
    MPC5554EVB
    Freescale
    MPC5553
    MPC5553EVB
    Freescale
    MPC55XX
    MPC5567EVB
    Document ListBack to Top
    Datasheet
    Part Number
    Description
    Size
    MPC5566 Microcontroller Data Sheet
    1.31MB
    SN74CBTLV3861-Q1
    123KB
    IS61SF25618
    256K x 16, 256K x 18 Synchronous Flow-through static RAM
    108KB
    TPA4861DRTPA4861DR
    TPA4861: 1-W Mono Audio Power Amplifier
    623KB
    HIN202EIBNZHIN202EIBNZ
    +5V Powered RS-232 Transmitters/Receivers with 0.1Microfarad External Capacitors
    493KB
    74LV125
    74LV125 Quad buffer/line driver 3-state
    906KB
    MC33394
    MC33394 Data Sheet
    642KB
    MC33661D
    542KB
    SN74CBT16211A
    SN74CBT16211A Data Sheet
    484KB
    DP83848
    DP83848VYB PHYTERRegistered - Extended Temperature Single Port 10/100 Mb/s Ethernet Physical Layer Transceiver
    148KB
    LMC7221
    LMC7221 - Tiny CMOS Comparator with Rail-to-Rail Input and Open Drain Output
    703KB
    SN74AC86
    709KB
    NC7SZ08P5
    536KB
    SN54ACT573
    SN54ACT573, SN74ACT573 OCTAL D-Type Transparent Latches Datasheet
    524KB
    SN74LVC2G125
    SN74LVC2G125 Dual Bus Buffer Gate Datasheet
    348KB
    Application Notes
    File Name
    Size
    AN3787 Preventing Device Lockout via Censorship on MPC55xx and MPC563x Families
    348KB
    AN3215 : Interfacing MPC55xx Microcontrollers to the MFR4200 FlexRay Controller
    608KB
    AN3007 : BLDC Motor with Speed Closed Loop and DC-Bus Break Controller, driven by eTPU on MPC5554
    2.2MB
    AN2859SW_FPM Frequency Pulse Measurement (FPM) eTPU Function API
    2KB
    AN2858SW_PPA Pulse Period Accumulate (PPA) eTPU Function API
    2KB
    Hardware & Software
    File Name
    Size
    Evaluation: CodeWarrior for ColdFire Architectures
    301MB
    CodeWarrior for ColdFire v7.1.2 Patch
    162MB
    301.6MB
    161.9MB
    Processor Expert - CodeWarrior for MPC55XX
    56MB
    MPC5500_GAP_TOOL
    8.4MB
    RAppID Version 2.2.0.7 IDE - Debug, Compile and Build Tools
    283MB
    MPC55XX_EEPROM_EMULATION_DRIVER
    4.45MB
    MPC55XX_FLASH_DRIVER
    4.9MB
    FreeMASTER Communication Driver
    4.3MB
    MPC5553 RAppID Demo Rapid Application Initialization and Documentation Tool
    55.3MB
    MPC5554 Processor Expert Init Tool
    18.7MB
    MPC55xx SPE DSP Library 1
    451KB
    MPC55xx SPE DSP Library 2
    2.5MB
    • at:demo_kit
    • sp:freescale
    • ap:mcu
    • at:tech_first_kit
