OMRON Electronic Components
  • OMRON Electronic Components
Forum Looking for a relay for a lift.
Join OMRON Electronic Components to participate - click to join for free!
  • Subscribers 12 subscribers
  • Views 2355 views
  • frontpage
  • omron
  • help!
alexsketchees
alexsketchees over 9 years ago
I have taken out 2 relays for a lift which are damaged for my father. He really needs this lift to get about. I cannot find these parts for the life of me and im worried if i get another brand it will break the lift as a whole. I have 2 relays i need finding if anyone could help. Ive typed out what it says on the cases below.
Omron LY4
12VDC
Contact
1/2 HP 120VAC
12A 240VAC
COIL 12VDC
switch sign 10A 220V ~ AC1
10A 24V - DC1
Variable resistor sign 12V
OC3
Omron MY4
12VDC
CONTACT
5A 240VAC
5A 28VDC
COIL: 12VDC
Id be extremely happy if someone could help here.
Your faithfully,
Alex
    dougw over 9 years ago +1
    element14 stocks Omron: LY4-DC12 OMRON INDUSTRIAL AUTOMATION, Power Relay, 4PDT, 12 VDC, 10 A, LY Series, Through Hole, Non Latching, Newark ele… MY4 DC12(S) OMRON INDUSTRIAL AUTOMATION, Power Relay, 4PDT…
    jw0752 over 9 years ago +1 suggested
    Hi Alex, I am glad that dougw found a source for your relays. You have peaked my curiosity though as I have never seen two relays fail in the same piece of equipment simultaneously without there being…
    jw0752 over 9 years ago in reply to Jan Cumps +1
    Hi Jan, I took it to mean a personal lift for helping a handicapped person get from the bed to a wheel chair or from a seated to a standing position like these: If it is something different perhaps Alex…
    0 dougw over 9 years ago
    MY4 DC12(S) OMRON INDUSTRIAL AUTOMATION, Power Relay, 4PDT, 12 VDC, 5 A, MY Series, Socket, Non Latching, Newark element…
    0 jw0752 over 9 years ago
    Hi Alex,
    I am glad that dougw  found a source for your relays. You have peaked my curiosity though as I have never seen two relays fail in the same piece of equipment simultaneously without there being a serious problem external to the relays themselves. Relays by their nature are very robust and do not fail easily. How have your relays failed? Do they have open coils or are the contacts damaged? What has led you to diagnose them as failed? You have probably figured this all out but just in case you haven't I would recommend testing the relay coils for continuity and if they are good using an external source of power to actuate them and check the continuity of the contacts. It might save you buying new relays only to find that there is a deeper problem.
    0 Jan Cumps over 9 years ago
    Isn't it mandatory that a lift is serviced and checked by a certified person?
    or is lift something different than elevator?
    0 jw0752 over 9 years ago in reply to Jan Cumps
    Hi Jan,
    If it is something different perhaps Alex can post a picture.
