Panasonic
  • Panasonic
Panasonic
Forum HAVE A QUESTION ON RESISTORS & INDUCTORS,ASK AN EXPERT!
Join Panasonic to participate - click to join for free!
  • Replies 16 replies
  • Subscribers 29 subscribers
  • Views 3641 views
Resistor+caps
Resistor+caps over 16 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Passive in the element14 Community Passive group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Max Jakob
Resistor&Inductor Specialist
  • hafcanadian
    hafcanadian over 13 years ago +1
    Forgive my ignorance, but I ultimately found my way here after watching the Ben Heck Show and learning about Element 14. I have little experience with electronics but hope to learn by immersion in discussions…
  • Andy_Brook
    Andy_Brook over 16 years ago
    Hi Max.
    I heard that all Panasonic chip resistors have flexible terminal technology, could you tell me a little more about this? it would make them ideal for automotive applications.
    Regards
    Andy
  • Resistor+caps
    Resistor+caps over 16 years ago in reply to Andy_Brook
    Dear Andy,
    Panasonic SMD Resistor use Soft Termination structure in order to provide solution against Temperature Cycle conditions at customers application (mainly automotive).
    Due to ROHS (Pb free soldering) especially in automotive application (where you have sometimes high, sometimes low temperature), Solder joint crackings happen in the solder fillet.
    Panasonic Soft termination structure help to minimize those crackings and absorb the stress, applied to the solder fillet by temperature cycling environment! Regards
    Max
    I am delighted to see that Farnell have decided to extend your range of Panasonic Resistors. I have been using your new SMD technology fantastic spec
    Max,
    I am doing a worst case analysis that has Panasonic thick film 1% resistors (100ppm).  I need to come up with a worst case value of resistors assuming -40DegC to 100DegC operating temperatures.   We are assuming about 2.8% which will include temp, end of life, soldering, vibration, temperature cycling, and any other condition that may change the parts.  Is that a good assumption or do you have a better number that we can use?   Also, statistically, what is the spread of tolerance for a 1% resistor?  Can we assume about 0.5% for the 6 sigma for the nominal analysis?
    Thank you.
    I need assistance in selecting the correct resistor to correct the output of a transformer. I have a 24v Singnal Transformer (CL2-25-24)(24V@1.05A). This transformer is powering a remote control receiver. The actual output of the transformer is 29.6V. The receiver has an input power range of 11-28V. I would like to limit the output power of the transformer to approx 27V. I have tried several resistors ranging from 3W-10W, 100 Ohm-250Ohm with no success. Please, what would you suggest?
    I need to know how to determine the wattage of a resistor by looking at it's size.  Can you help me with this?
  • Resistor+caps
    Resistor+caps over 14 years ago in reply to e14 Contributor
    It depends on technology
    Even same case size might have different wattage due to different heat dispersion structure, different material
    Hi Max,
    On behalf of one of my customer I would like to ask about one Epcos product MPN  B82131A5402MB82131A5402M stocked also by Farnell He needs to know some detailed information about the electro-magnetic attributes of the material the product is made of(Carbonyl Iron Could you please advise
    Thank you
  • Resistor+caps
    Hello
    Thank you for your mail, unfortunately Max is here to Answer questions on Panasonic only.
    Please contact Epcos directly
    Thank you
    Panasonic Administrator
    I have a zener diode (not sure it was manufactured by Panasonic) with colour band on the lead and on the body as per below:
    Lead - red
    Body (nearest to the lead with red band) - brown
    Body - blue
    Is there anyway to tell what is the part number based on these colours bands?
