Rohm Semiconductor
  • Rohm Semiconductor
Rohm Semiconductor
Blog Ultra-low noise op amps enable high accuracy sensing
Join Rohm Semiconductor to participate - click to join for free!
  • Author Author: rohm
  • Date Created: 5 Nov 2019 1:16 AM Date Created
  • Views 1161 views
rohm
rohm
5 Nov 2019
As sensors are devices that convert physical changes in the environment into sensor signals, the performance of op amps used to amplify and transmit minute sensor signals can significantly benefit from increased accuracy.
ROHM’s LMR1802G-LB CMOS op amp contributes to the advancement of devices that demand ultra-low noise characteristics and high accuracy sensing.
Feature 1: Ultra-low-noise
Breakthrough ultra-low noise characteristics makes it possible to support even weaker sensor signals than currently possible, significantly improving detection performance.
Feature 2: Reduces op amp errors
In addition to low input bias current characteristic of CMOS, input offset voltage is reduced by 4x over conventional products. This minimizes op amp error factors, further increasing application accuracy.
Product LinkProduct Link
ROHM ultra-low noise op amps contribute to higher accuracy and relability in sensor applications.
