SV Microwave
  • SV Microwave
SV Microwave
Blog 30° Angled PCB Connectors - In Stock!
Join SV Microwave to participate - click to join for free!
  • Author Author: Murugesan
  • Date Created: 15 May 2024 2:32 PM Date Created
  • Views 882 views
  • 30° Angled PCB Connectors
  • Angled PCB Connectors
  • 30° PCB Compression Mount Connectors
  • 30° Solderless PCB Compression Mount Connectors
Murugesan
Murugesan
15 May 2024
SV Microwave newly launched the 30° Angled Solderless PCB Compression Mount Connectors. Its brand-new body orientation is angled 30° away from the PCB. The major reason behind this thoughtful design is to improve the electrical performance over the standard surface mount PCB connectors. You can achieve edge launch-level performance across the board. Since these are solderless connectors they can be installed quickly.
Features and Benefits
  • It offers improved electrical performance over standard surface mount connector
  • Connectors are reusable and easily replaceable
  • Available in 1.85 mm, 2.4 mm, 2.92 mm and SMA series
  • Dielectric withstanding Voltage 500 VRMS for 1.85 mm and 2.4 mm, 750 VRMS for 2.92 mm and 1000 VRMS for SMA
  • Temperature Rating -65°C to +165°C
  • 500 mating cycles
  • DC – up to 65 GHz
Applications
  • Ideal for high speed/frequency component test
  • Applicable in product evaluation boards
  • Mil-Aero Radar and communication systems
  • Satellite communication system applications
Discover the detailed and technical specifications of 30° Solderless PCB Compression Mount Connectors at SV Microwave.
  • Murugesan
    Murugesan over 1 year ago
    This innovation is within your reach!
    The 30° Solderless PCB Compression Mount Connectors are now in stock. Order yours today and experience the difference: svmicrowave.com
    DAB over 2 years ago
    Very good idea, those flat connectors are a pain to attach and detach.
