SV Microwave
  • SV Microwave
SV Microwave
Blog Pre-Tinned (De-Golded) Connectors
Join SV Microwave to participate - click to join for free!
  • Author Author: Murugesan
  • Date Created: 22 Mar 2024 8:06 AM Date Created
  • Views 604 views
  • Pre-Tinned Connectors
  • De-Golded PCB Connectors
  • De-Golded Connectors
  • Pre-Tinned PCB Connectors
  • SV Microwave Capabilities
Murugesan
Murugesan
22 Mar 2024
SV Microwave has designed and developed Pre-Tinned De-Golded PCB Connectors for a wide range of applications.
De-Golding Method in SV Microwave
SV Microwave has an exclusive and proprietary technique to eliminate gold from the solder region of our RF connectors. In the design stage, we strategize gold removal by altering the connector body to facilitate efficient fixturing and ensure thorough removal of gold from the solderable region, including nearby areas susceptible to capillary effect wicking. Discover the SV Microwave’s Pre-Tinned (De-Golded) PCB Connector and place your order today.
Top Features & Benefits
  • Gold in soldered area removed per J-STD-001
  • Improves reliability of the solder joint
  • Connectors optimized for pre-tinning at the design stage
  • Parts delivered in T&R packaging and ready to install
  • Cost savings compared to outsourcing or de-golding in-house
  • Pre-tinning options are available in both SN63 and SN96
  • Robust technical support for design, assembly and troubleshooting
  • Footprint design optimization through simulation available
Applications
  • Ideal for Military and Aerospace Radar Transmit/Receive units
  • Space and High Reliability Communications and GPS applications
  • Applicable in where any time de-golding is a concern or requirement
  • Applicable in Embedded Computing
  • Harsh Environment applications
