SV Microwave
  • SV Microwave
SV Microwave
Blog SV Microwave’s Embedded Phase Tuner
Join SV Microwave to participate - click to join for free!
  • Author Author: Murugesan
  • Date Created: 13 Sep 2024 9:23 AM Date Created
  • Views 574 views
  • sv microwave
  • Challenges in Phase Matching
  • Embedded Phase Tuner
  • SV Microwave’s Embedded Phase Tuner
Murugesan
Murugesan
13 Sep 2024
Phase matching is the process of maintaining the same phase in cable assemblies as the signal travels along different paths or through different components. Traditionally it requires multiple tests and actions. The process is long and expensive. Any modifications to the phase require collaboration with external vendors.
SV Microwave introduces an innovative Embedded Phase Tuner. This one allows the customer to independently adjust the phase of the cable assemblies without any external vendors. It doesn’t require adapters for transitioning between different cable diameters. A threaded coupling nut simplifies the process of phase adjustment. Explore our Embedded Phase Tuner and check out the electrical specifications.
Features and Benefits
  • The component is smaller than traditional line stretcher
  • The tuner can be positioned anywhere within the cable assembly, allowing for flexibility in design
  • It can be used on any cable type
Applications
  • Ideal for Test and instrumentation
  • Phased-array RADARs
  • Military and Aerospace applications
