TE Connectivity
  • TE Connectivity
TE Connectivity
Forum Custom connectors to meet customer demand
Join TE Connectivity to participate - click to join for free!
  • Subscribers 20 subscribers
  • Views 275 views
  • connector
  • custom
  • manufacturer
For most connector manufacturer, they are likely to have such an area, which is the custom connector, including according to customer requirements, design to produce high-end connectors, such as R022 miniature connector, it is a typical custom connectors, brief introduction as follows:
■ Contacts:16,25,30,36,50 pins,etc.
■ Solid pin and spring wire socket , small shape, high reliability
       of connecting
■ Sectional area of the cable 0.035mm2 ~0.1mm2
■ This product is mainly used to connect the connection of computer PCB
        or electric appliance
    ■ Standard: E/SC-A(05)-87-2007
Environment temperature:
-65℃ ~125℃
Relative humidity:
95% when 40℃
Low air pressure:
1.33kPa 150V
Vibration:
10Hz ~ 2000 Hz  147m/s2
Shock:
980 m/s2 6ms
Rated current:
1A
Contact resistance:
≤10mΩ
Insulation resistance:
≥5000MΩ ( sea level)
Dielectric strength:
1000V
Durability:
500 times
