TE Connectivity
  • TE Connectivity
TE Connectivity
Forum Ruggedized Optical Backplane interconnect system
Join TE Connectivity to participate - click to join for free!
  • Subscribers 20 subscribers
  • Views 271 views
PIC_Spain
PIC_Spain over 12 years ago
Do you have questions on any TE / AMP brand product?  Ask me!
I am here to answer any questions you may have on TE and AMP brand products.
Do you know that the Ruggedized Optical Backplane interconnect system providesa high-density, blind-mate optical interconnect in a blackplane/daughter card configuration?
TE Connectivity’s (TE) Ruggedized Optical Backplane interconnect system provides a high-density, blind-mate optical interconnect in a backplane/daughtercard configuration. The fiber optic (ribbon) cable interconnect is fed through the backplane to removable system modules using MT ferrules.
Product Features
  • Supports VITA 66.1 Standard
  • Connectors designed to maximize optical performance and accommodates up to two MT ferrules
  • Locating post features helps ensure proper position on the backplane and module boards
  • Common protective cover is made of anti-static material
  • Plug (daughtercard) connector housing contains a slot feature to facilitate cleaning the MT interfaces
  • Receptacle (backplane) connector includes two robust guide pins for blind-mating
  • Receptacle connector insert floats relative to the shell providing ±0.25mm planar floating alignment capability
  • Connector mounting screws contain pre-applied Nylok patch to withstand vibration
Applications
  • Embedded Computing
  • Avionics and Vetronics
  • Secure Communications
  • Radar
  • Processing
  • Imaging and Targeting
imageENG_DS_1-1773708-2_optical_backplane_1113_1-1773708-2_optical_backplane[1].pdf
