TRACO POWER
  • TRACO POWER
TRACO POWER
Forum Traco start up
Join TRACO POWER to participate - click to join for free!
  • Subscribers 2 subscribers
  • Views 1327 views
Traco start up
Has anyone had problems with Traco DC-DC TEN15 2422WI converters not starting up correctly with no or low loads
  • Oliver
    0 Oliver over 17 years ago
    Does it work with rated load?
  • koh
    0 koh over 17 years ago
    TEN5-2422WI starts all the time as long the input voltage is within the specifications and no short circuit is applied on he output.
    With no load or less than 10% load the converter may provides a higher ripple and output voltage is due to the ripple less stable.
    The datasheet specifies output load regulation from 10% to 100%. Below 10% do not give any specifications.
    If your load is less than maybe a TEN3-2422WI is the better choice.
    http://dsb.tracopower.com/upload/dsbuserfile/cpn_tracopower/0_ten3.pdf?150920090823573023792
