VPG Foil Resistors
  • VPG Foil Resistors
VPG Foil Resistors
Documents APR Series: Standardized Precision, Delivered Fast
Join VPG Foil Resistors to participate - click to join for free!
  • Author Author: Tomhazan1
  • Date Created: 9 Sep 2025 7:09 AM Date Created
  • Last Updated Last Updated: 9 Sep 2025 7:55 AM
  • Views 216 views
Reliable. Standardized. Ready-to-Use.
APR – Standardized Precision Resistors by VPG Foil Resistors deliver dependable performance for high-volume, cost-effective applications across industrial, automotive, power, and communications sectors. Designed for when “better is good enough,” the APR portfolio includes metal strip, foil, thin film, and thick film technologies—offered in made-to-stock formats that balance price and performance.
From AEC-Q200 compliant SMD current-sense resistors to high-voltage leaded wirewound models, APR resistors are available in tape-and-reel, axial, radial, and PCB module configurations. These resistors support resistance ranges from micro-ohms to tera-ohms and feature stability under load life, with TCRs as low as ±3 ppm/°C and tolerances down to ±0.005%.
APR resistors are engineered for EV charging, 5G infrastructure, power modules, and instrumentation, providing reliable measurement, thermal stability, and delivery agility.
Read the brochure here: APR Standardized Precision Resistors Brochure
  • Surface Mount Foil Resistors
  • resistors
  • Power Current Sense Resistors
  • bulk_metal
  • high-precision
  • foil_technology
