PCB Design, Prototyping and Production
PCB Blogs KiCAD 8: RX23E-B kit - clock, debug and reset schematic
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Date Created: 28 Oct 2024 7:36 PM Date Created
  • Views 1969 views
  • Comments 6 comments
  • kicad
  • rx23E-B
  • renesas
28 Oct 2024
I'm building a PCB for Renesas' RX23E-B microcontroller. In this post, I experiment with breaking the microcontroller schematic symbol into functional units. And I created some custom symbols and footprints.
Schematics
I'm interested to hear what you think about the schematic approach and layout choices. Some things I did for this schematic:
  • I first created a full (100 pin) symbol for the microcontroller. And for this design, split it in several functional units, to fit the schematics layout. U1E in this schematic is the unit that contains clock, reset and debug pins.
  • I created a custom schematic symbol for the TE Connectivity FSM1LPS switch.
  • I tried to arrange and group the overall schematic to feel natural
  • I attempted to limit the number of functions covered in this schematic page. The "utilitarian" functions clock, debug and reset.
  • The RX23E-A symbol I created supports alternative pin function . The schematic shows the function that's default (and sometimes the hard choice) for my design.
Footprints
For the switch and subclock oscillator , I created a custom PCB footprint.
Switch FSM1LPS (footprint)- corrected. See misaz comment below
image  image
Crystal SSP-T7-FL:SSP-T7-FL (footprint)
image image
I will probably have to refine them once I created the PCB. But the pads are where they should be. Would you draw these differently?
    Jan Cumps over 2 years ago
    Comparison: this is Renesas' style of schematic drawing. My design is heavily borrowing from this. But not from the style.
    Jan Cumps over 2 years ago in reply to Jan Cumps
    for history: this was my wrong pad layout:
    I tried to address both comments
    Pins renumbered as caught by misaz .
    michaelkellett , related to the yellow lines (silkscreen):
    I created some more space for the pads - haven't measured yet, but will check for the clearance with the pads.
    For the line width: I adapted this part from one of the stock-KiCAD footprints. Almost all parts use that same width...
    Jan Cumps over 2 years ago in reply to misaz
    no. Thank you - you saved me from a respin Slight smile
  • michaelkellett
    michaelkellett over 2 years ago
    I like parts separated into functional blocks, although it often means re-drawing blocks according to the requirements of each new design.
    I can't be sure, but the yellow component outline looks much too thin and much too close to the copper pads.
    Most pcb houses struggle with silk screen features less than 0.15 mm line width and pad to silk screen gaps of less than 0.15 or 0.2mm.
    But it may not be correctly scaled on the footprint pictures.
    MK
