PCB Design, Prototyping and Production
PCB Blogs Raspberry Pi RP2350 based PCB design
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Author Author: embeddedguy
  • Date Created: 19 Jun 2025 8:16 AM Date Created
  • Views 3542 views
  • Likes 10 likes
  • Comments 16 comments
  • pcb
  • raspberry pi
  • rp2040
embeddedguy
embeddedguy
19 Jun 2025
Sometimes back, I was designing a PCB based on RP2350 and now I received the finished PCB. So this post is about the experience that I would like to share about my PCB design.
Firstly, the original plan of creating this PCB was to create RP2350 based Single Pair Ethernet development board. For that I had used ADIN-1111 chip. Unfortunately, it was not available during the PCBA making. Hence the original idea was not possible. But I have tested the RP2350 chip and it is working fine.  The design is based on KiCAD and is 4-layer design.
The easiest idea to test this board is to use Micropython so that the board can be tested fast. I tested a simple blink program on this board and it works fine.
  • BigG
    BigG over 1 year ago +1
    Very nice. Does your SPE board include PoDL (power over data lines)? That's a design challenge just on it's own. I've always fancied the microchip SPE ICEs over ADIN-1111, purely on price. I see Arduino…
  • embeddedguy
    embeddedguy over 1 year ago in reply to BigG
    No, PoE would be interesting but complex than this simple PCB. I chose this chip because of low pin count and simple interface.!!
    Microchip has SPE but as far as I know there are two variants in SPE, and they do not have 10-BASE-T1-L. here L is for long range.
    DAB over 1 year ago
    Nice build.
    I look forward to your testing of its capabilities.
  • BigG
    BigG over 1 year ago in reply to embeddedguy
    Stencils are now an easy add-on when getting boards made at fab house. Then just need solder paste and hot plate. It's never perfect but SMD soldering this method is also easier than anticipated.
  • BigG
    I've always fancied the microchip SPE ICEs over ADIN-1111, purely on price. I see Arduino recently launched their SPE shield with microchip.
  • embeddedguy
    embeddedguy over 1 year ago in reply to wolfgangfriedrich
    Yes, I will for sure, I received this PCB two days ago. I was waiting for it to arrive and check that it is working.
    Also, I need to find someone who can probably do SMD soldering because I have tried that in the past and I cannot.Smirk
