PCB Design, Prototyping and Production
PCB Forum Is this a Linux KiCad 7 Bug or something I am doing wrong
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 159 subscribers
  • Views 1919 views
  • kicad 7
  • kicad 6
colporteur
colporteur over 3 years ago
There is missing field in my 7.0.6 verson of KiCad under Ubuntu
I switched back to KiCad 6 and the field are there.
I'm not sure if this is a operating system related or my install. I only recently moved to KiCad 7. Now that I am using it I begin to notice some anamolies. I was trying to establish track widths in PCB editor that lead me to this.
  • baldengineer
    baldengineer over 3 years ago +4
    The net class filter UI changed in KiCad 7. Bluntly, I find the new design very unintuitive. The list of nets is no longer shown. Instead, as a human with vastly more memory and processing capability…
  • Andrew J
    Andrew J over 3 years ago
    It's not clear to me what your actual problem is.  You say missing field, but what missing field?  Is the top image 7.0.6?  It looks to me that instead of having the net filters, you do it by creating a pattern and it shows all the nets that match that pattern and you assign the net class to it (and thus the matching nets.)
  • baldengineer
    The list of nets is no longer shown. Instead, as a human with vastly more memory and processing capability than your computer, you must memorize the net names (especially the internally generated ones) to type in the pattern you wish to match manually. And don't worry; it has to be an exact match or one with undocumented wildcards for extra difficulty! Although astrix(*) tends to work, sometimes, but not others. For some reason.
    (Totally valid, in my opinion,) Sarcasm aside, that is how KiCad 7 works now.
  • Andrew J
    Andrew J over 3 years ago in reply to baldengineer
    Really???  I've not changed yet, but good Lord.
  • colporteur
    colporteur over 3 years ago in reply to baldengineer
    I'm not following the thread or the sarcasm.
    So this is normal for version 7?
  • baldengineer
    baldengineer over 3 years ago in reply to colporteur
    Yes. The UI/UX was changed in version 7 to what you see now.
    There is no longer a list of available nets (in that dialog).
    You have to know the name of the nets before you setup the filter.
  • colporteur
    Manged to weed my way through. Talk about a step backwards. The netclass sizes now work.
    The scenario of missing fields I have in another program called Inkscape. It happened after an upgrade. I made the same assumption with this.
    Thanks for chiming in.
  • colporteur
    colporteur over 3 years ago in reply to colporteur
    After closer examination I discovered the Pattern GND connections picked up the Net Class of Power and applied the desired the assigned track width. The Pattern +5V would not pick up the desired track width and used the default. I could right-click customize the +5V track width to the required length but it would not work with the Net Class.
    I did have this working on KiCad 6 but this is my first real end-to-end test of 7. I'm not sure why net class works for GND and not +5V:)
