PCB Design, Prototyping and Production
PCB Forum CM4 integration and thermal consideration
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Subscribers 160 subscribers
  • Views 909 views
AlfiereInnovation
AlfiereInnovation over 2 years ago
hello group,
I am designing a carrier board to integrate a CM4 into my project. Due to the thermal needs of RPI chips, in particular on the CM4 board, I am thinking about adding a thermal pad between the CM4 and my carrier, creating a sort of sandwich configuration. this pad will touch on one side the CM4, and on the other side my carrier board, in a region that I will populate with exposed ground with vias to connect to the other side of the carrier.
basically, I would like to use the PCB as heat sink, and add a sheet metal heat sink on the back part to the carrier to help the thermal performances.
the layered structure will be something like:
--------- CM4
--------- THERMAL PAD
--------- CARRIER BOARD TOP COPPER LAYER
--------- CARRIER BOARD BOTTOM COPPER LAYER
--------- SHEET METAL HEAT SINK (plenty of space on this side)
what is your experience with such a solution?
do you have any consideration to share?
thank you,
Luca
    dougw over 2 years ago +1
    It sounds feasible if everything stays in good contact, but you should do a thermal analysis to ensure there is enough heat flow to keep the temperature rise within acceptable limits.
  • mayermakes
    mayermakes over 2 years ago +1
    Sucking heat through the pcb is not ideal, but may work good enough. a simple sheet metal heat transfer on the upper side could help more if there is no room for a real heatsink.
  • AlfiereInnovation
    AlfiereInnovation over 2 years ago in reply to dougw
    thank you for the quick feedback. I wonder also if the CM4 board can achieve a sufficient dissipation and heating transfer if only from the back. based on the location of the connectors, I can only touch the back of the board actually. until now, I used the RPI zero form factor, which allowed RPI upside down and thus to have the top layer facing the thermal pad. I wonder if you have any direct experience on that. thank you for your feedback!
  • mayermakes
  • AlfiereInnovation
    AlfiereInnovation over 2 years ago in reply to mayermakes
    Yes, I know, I am actually looking for other's experiences on that before I build my own test pcb.
    Thank you
