    • Avnet Boards Community
PCB Design, Prototyping and Production
PCB Forum KiCad 8 is here!
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Replies 32 replies
  • Subscribers 128 subscribers
  • Views 6080 views
  • kicad 8
  • kicad
KiCad 8 is here!
shabaz
shabaz over 1 year ago
Installing KiCad 8 went smoothly.
First off, I went to my KiCad project folder (e.g. C:\KICAD_PROJECTS), and made a backup copy of it. Then, I installed KiCad 8. At the prompt,I chose to import settings from KiCad 7:
It started up just fine, with my previously opened project all ready for me in the new KiCad 8.
After that, I went to my old KiCad folder in C:\users (C:\users\shabaz\Documents\KiCad\7.0) and copied everything there to C:\users\shabaz\Documents\KiCad\8.0.
Clicking on Symbol Editor or Footprint Editor will bring up a prompt. I selected the default:
When in the Symbol or Footprint editors, the default KiCad libraries will be there, but any user-created ones won't be. I clicked on File->Add Library and navigated to C:\users\shabaz\Documents\KiCad\8.0\symbols or \footprints respectively, and selected my user library and it got added.
I've not tried much so far, but very happy that this feature is available:
The above will speed up footprint creation/editing a lot. It is a feature that was sorely missing, it should have been added years ago.
I don't know if the 'teardrops' feature is new, but I've only noticed it now in KiCad 8:
I'm looking forward to exploring more in the next few weeks (I will use KiCad 8 unless I hit any showstopper; I still have KiCad 7 and KiCad 6 installed, I think it's time to remove v6!).
    Jan Cumps over 1 year ago +6
    baldengineer posted a top-8 of new features on his youtube channel . I endorse that message .
  • baldengineer
    baldengineer over 1 year ago in reply to genebren +4
    For what it is worth, the last time I used Eagle was in 2015. I've done about 50 PCBs since then. Granted, most of them were small breakout boards. However, since then, I have not found a single case where…
    shabaz over 1 year ago in reply to BigG +3
    A bit clunky using it, but eventually got a simple circuit working. This was with a op-amp SPICE file pulled from the web. In short, it all majorly revolves around two main points: (1). In the symbol…
  • colporteur
    colporteur over 1 year ago
    I did the online training for KiCad 6 and rather enjoyed it. They are now boasting KiCad 8 updates.
    https://techexplorations.com/blog/kicad/kicad-8-new-and-updated-features-review/
    I've raised a couple of bugs on v8 yesterday, but nothing super-critical. They are related to CADSTAR import.
    It's nice that things move swiftly. The issues have already been reproduced.
    This was with a op-amp SPICE file pulled from the web. image
    (1). In the symbol properties, insert the SPICE model by clicking on Simulation Model, and definitely remembering to set the SimPins parameter to correctly match the contents of it to the symbol!
    and (2), use the symbol library called Simulation_SPICE for all the various voltages/signals to be modeled. Like most SPICE simulators, you need to use the specific symbols for voltages and ground. so if you're using other symbols in the schematic for those, then you'll need to connect them (as I have done in the example screenshot above).
    Then you can click on Inspect->Simulator and generate the simulation by clicking on the blue triangle. If your wires have labels (like IN or OUT etc) then that makes it easier to plot.
    Not sure I'd enjoy using it regularly, but glad it's there, and I hope they add more usability for it in the future!
  • baldengineer
    baldengineer over 1 year ago in reply to shabaz
    A couple of bugs I reported with the release candidates were fixed within a day! (They were probably quick fixes, but still...)
    shabaz over 1 year ago in reply to baldengineer
    Hehe GitHub gives badges if you are super-quick with a fix, like if you close an issue within minutes of it being opened : ) I hope GitLab awards something similar for those kind of speed demons!
    You get a dubious YOLO badge if you skip the code review!
    I'm installing it today. Also a good excuse to start designing some circuits.
    shabaz over 1 year ago in reply to Jan Cumps
    I've used it a bit so far, raised a couple of bugs (one crash) but generally it seems fine. I found I couldn't align parts on the PCB as easy as before, it sometimes wouldn't select the pad center (and instead would snap to the grid) when grabbing and moving components, but that may be a config setting, either new or something that didn't migrate properly from existing config. I didn't look in detail. I'll investigate a bit more to get to the bottom of that next time I try it.
    KiCad 8.0.1 released. Definitely worth upgrading, since there are many bux-fixes.
  • anniel747
    anniel747 over 1 year ago in reply to shabaz
    shabaz said:
    bux-fixes
    Bug?
    Jan Cumps over 1 year ago in reply to shabaz
    I just installed it. Got a pop-up when starting 8.0.0.
