PCB Design, Prototyping and Production
PCB Forum Question LCD display storage
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Replies 17 replies
  • Subscribers 161 subscribers
  • Views 2403 views
  • lcd
cloudff7
cloudff7 over 1 year ago
Will long-term storage of years on a 3.5" IPS LCD display cause disorganization, confusion and slowness in the liquid crystals, dead pixels and loss of brightness and performance in the backlight LEDs?
    michaelkellett over 1 year ago +4
    LCDs can last quite a long time - I have some that still work OK after >30 years. There is no experience of how long modern types of LCD will last (they haven't been around long enough). You will need…
    shabaz over 1 year ago in reply to cloudff7 +3
    Those consoles are low-cost, they with have the cheapest consumer electronics displays, so you should set your expectations accordingly. In any case, there are bound to be better systems in the coming…
    shabaz over 1 year ago in reply to cloudff7 +2
    You're expecting way, way too much. This isn't how low-end consumer electronics works. No datasheet will help you determine the quality of what you have in those consoles, and the best quality displays…
    dougw over 1 year ago
    I would guess it is mostly due to mechanical (physical) creep or warping.
    You will need to consult manufacturers to get information about this and unless you have significant credibility (they think you will buy lots) it will be very difficult to get information and even harder to get a guarantee.
    The actual life time of an individual LCD will depend on the underlying technology and the quality if the materials and production.
    If you need parts with exceptional performance and quality expect to pay an exceptional price.
    You can test parts buy exposing them to the highest safe operating temperature and measuring their actual lifetime, and then assuming that the life will double for every 10K cooler that they are actually stored at.
    Why do you care - what is the application ?
    If it's the countdown timer on a nuclear waste store - don't use an LCD.
  • cloudff7
    cloudff7 over 1 year ago in reply to michaelkellett
    my electronics that use these IPS LCD displays are R36S and Powkiddy Q80 consoles and my storage conditions 34-36C 58-68%
    • Vote Up -1 Vote Down
  • anniel747
    anniel747 over 1 year ago in reply to cloudff7
    [deleted]
  • cloudff7
    cloudff7 over 1 year ago in reply to anniel747
    i removed batteries and store
  • cloudff7
    What are the conditions for long-term storage of 3.5" IPS LCD display to avoid loss of brightness and performance in LED backlight and liquid crystals confusing disoriented and slow and dead pixels?
    Those consoles are low-cost, they with have the cheapest consumer electronics displays, so you should set your expectations accordingly. In any case, there are bound to be better systems in the coming decades, so chances are high you'll still be able to play the same games if you want, even if it's on a different system.
  • cloudff7
    cloudff7 over 1 year ago in reply to shabaz
    I searched but I couldn't find the datasheet for the displays of these two consoles. Is there a datasheet for a low-cost 3.5" IPS LCD similar to these two displays to have storage information that is closer and similar to the display of these consoles?
    You're expecting way, way too much. This isn't how low-end consumer electronics works. No datasheet will help you determine the quality of what you have in those consoles, and the best quality displays won't necessarily interwork anyway. If you want a rugged portable console, then buy something like a Panasonic Toughbook and install the emulator on it. Even that won't be entirely long-lasting. You could then consider a military laptop. How much are you willing to spend?
  • ariajames_121
    ariajames_121 over 1 year ago
    Yes, over years, long-term storage can lead to issues like dimmer backlight (LED aging), potential dead pixels, or slower LCD response especially if stored in poor conditions like high heat or humidity. Proper storage helps reduce these risks.
