PCB Design, Prototyping and Production
PCB Forum Logic Gate Output Changes When Nearby Relay Activates
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Subscribers 161 subscribers
  • Views 469 views
eva_402
eva_402 7 months ago
I’m using a few AND/OR logic gates to generate enable signals before they enter a microcontroller. The logic works normally, but sometimes outputs change briefly when a nearby relay switches.
The relay and logic ICs are on the same board.
Questions:
  1. Is this more likely EMI coupling or supply disturbance?
  2. Should I add more decoupling or flyback suppression first?
  3. On the PCB, is physical separation between relay components and logic ICs usually enough?
  • acdc90
    acdc90 7 months ago +3
    is the gates powered on 5volts is the relays on 5v or 12v does the relay have diode across coil can we have a circuit ?
  • robogary
    robogary 7 months ago +2
    Depends. Is the relay switching an inductive load ? If possible, you could remove the relay's load and cycle to see if that is related to misoperation. Relay coils should have a flyback diode (or a…
  • acdc90
    0 acdc90 7 months ago
  • robogary
    0 robogary 7 months ago
    Relay coils should have a flyback diode (or a shottkey double back diode tvs) unless it effects any critical timing. Larger coils should also have RC suppression.
    If your relay switches an inductive load like a motor or solenoid, that load should also have suppression. The suppression will also ensure the relay contact life.
  • colporteur
    0 colporteur 6 months ago
    I've experienced the interference from relays in digital electronics. The components don't even have to be on the same board. Mostly working with Arduino's and raspberry pi. My fix was to code to simulate key bounce. relay contacts under heavy load do tend to generate emf. Its never seems to be good for the contacts and the surround environment. I can give you empathy but not a practical solution.
    0 DAB 6 months ago
    Never underestimate the value of metal shielding.
    Also, ferrite cores can be very useful in reducing induced spikes.
