PCB Design, Prototyping and Production
PCB Forum Using dxf as board outline
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Subscribers 163 subscribers
  • Views 793 views
arny64
arny64 over 9 years ago
Hello so i have drawn a dxf for my board outline in eagle not a terribly complex shape http://www.takachi-enclosure.com/data/c16-17/2016-043-48.pdf#6 .But when i import the dxf file into eagle using the import-dxf.ulp script i get some pretty rough edges on the arc and curves and some little tiny lines show up on the top copper layer.Iam more concerned of the tiny lines running across the top copper,but Is this just the limits of this script or is there anything i can do to round out all the rough edges and get rid of the lines thanks?
  • rachaelp
    rachaelp over 9 years ago
    Hi ***,
    You might be better to consider moving this over to the EAGLE support section of the forum here: https://www.element14.com/community/community/cadsoft_eagle/forums/support_eng
    I've not used the dxf import that often but when I have used it it seemed to work ok and I didn't see anything odd. What version of EAGLE are you running? Can you either upload your dxf, or give a screenshot of what you are seeing then we might be able to help a bit more.
    Best Regards,
    Rachael
  • arny64
    will do thanks thought i posted in the right section oops.
