Raspberry Pi Forum Yet another Pip-Boy project
  • Replies 17 replies
  • Subscribers 704 subscribers
  • Views 4666 views
lordzoabar
lordzoabar over 6 years ago
Hardware:
Raspberry Pi Zero-W
Adafruit Ultimate GPS breakout
Adafruit I2S 3W Amplifier breakout
Fallout 76 Pip-Boy 2000 MKVI kit
various tactile switches and rotary encoders
*no monitor decided on yet*
So I’ve been working on my own Pip-Boy project, and I’ve run into a snag.   I am using the Raspipboy Python program made by Selectnone years ago, (https://bitbucket.org/selectnone/raspipboy/wiki/Home) and have been running into a number of problems.   I want to use it, as it is the most “complete” PipOS I have found (and I know NOTHING about how to even start writing my own).  It was originally written in Python2, but I’ve been able to update my local copy of it to 3.7.  I tried keeping it in Py2, but I get the same issues as I do when running it in 3, and 3 runs faster, anyway.   I’m not at home at the moment, so I don’t have the traceback logs in front of me, but pretty much, every time it makes a call to GPSD to draw up the maps when the Data-Maps tab is opened, it crashes.   If I could just disable the maps tabs, that would be fine with me even, but I don’t know how to safely do that without completely breaking everything else.   If anyone familiar with Python would be willing to take a look at the script package, I can relay all the changes I’ve made, (mostly through trial and error).  If anyone knows of another good PipOS that’s been written, that actually works, I would greatly appreciate that as well.
  • lordzoabar
    Is there anything anyone else can figure out or assist with?   I’ve already got all the components, and everything works individually.  I would hate to have to just give up on this project all because of a programming issue that I can’t find...  image
  • onewhosighs
    onewhosighs over 5 years ago in reply to lordzoabar
    I'm working with the same script and having the same error (TypeError: 'NoneType' object is not iterable). I believe this error is present because google maps API now requires an API key.
    If you manually go the the URL in the script it says you need an API key. I've got nowhere on fixing it though
  • cstanton
    cstanton over 5 years ago in reply to onewhosighs
    API Key?
  • onewhosighs
    onewhosighs over 5 years ago in reply to cstanton
    Managed to get a key but no idea how to tell the scripts to use it - it’s not a simple “go to address and return X Y”
    not at PC so I can’t get the script up right now
  • cstanton
    It'll probably need to setup a 'handshake' where it passes the API key to it initially or whenever it requests information, what'll be important is how the script currently does that and how it relates to what works in google's documentation.
  • lordzoabar
    lordzoabar over 5 years ago in reply to cstanton
    I’m going to have to go back and take another look at that.  I have an api key, but idk if it was ever actually using it, or if I was using the wrong key entirely.
    shabaz over 5 years ago in reply to lordzoabar
    Just as a general rule, when working with APIs, it is often a lot easier to confirm the API URL, syntax etc., and credentials for any authentication and authorization, and any formats for sent and received data, separately, before trying to put it into the microcontroller code or Pi. Then by the time you're ready to try coding it, you already know in advance that the key is correct and that any formats for sent or received data is correct. One way to test it all out first, is to (say) download an app called 'Postman'. There should be some online guide how to use it, but it has a mostly self-explanatory user interface. Once you've achieved it, the knowledge will be relevant to future API experimentation too, since many of Google's APIs will use a similar method perhaps.
