Raspberry Pi Forum Raspi 3 ping
  • Replies 18 replies
  • Subscribers 709 subscribers
  • Views 2226 views
Raspi 3 ping
k5at
k5at over 10 years ago
on all my Raspi 2's, I can open a terminal window and ping either a IP address for a domain name.
I have to be in root to do so on the Raspi 3.   What gives?
    shabaz over 10 years ago in reply to clem57
    vcgencmd version
    Feb 25 2016 14:25:47
    Copyright (c) 2012 Broadcom
    version dea971b793dd6cf89133ede5a8362eb77e4f4ade (clean) (release)
  • clem57
    clem57 over 10 years ago in reply to shabaz
    k5at
         Ok install rpi-update if you do not have. See https://github.com/Hexxeh/rpi-update  for details.
    Then taking the string in shabaz coment you can go back to his level using (warning double check), See https://tech.enekochan.com/en/2014/03/08/upgradedowngrade-to-a-specific-firmware-kernel-version-with-rpi-update-in-raspb…
    sudo rpi-update string
    Of course you can go back as well if you have your prior string. Hope you have a backup strategy and will need a reboot.
    Clem
    Warning: Not to be done unless you take all risks! You have been warned...
  • rew
    rew over 10 years ago
    Ping needs to inject "low level" packets into the network. As that is a rather "unusual" operation it does not make sense to build a kernel-interface specifically for that. There is just a PROGRAM specifically for that. This program is called "ping".
    So, the ping program needs to ask the running Linux system: "hey, I built this odd network packet, could you inject it into the network for me without any security or sanity checks?" This requires elevated (root) privileges..... But ordinary users have a valid requirement for running "ping", so there is a solution for this: The ping program was made "setuid-root". The ping program, and that program alone, gets while it is running the privileges of the root user, allowing it to do the packet injection it needs to do. The trade-off is that the ping program needs to be written securely.
    So where a normal program say: "nano" could get away with crashing if instead of "nano /etc/bash.bashrc" you enter "nano /etc/<.....kilobytes or megabytes of string data ....>", a setuid program like ping will have to check its arguments very carefully, because a "crash" usually means that a carefully crafted humongous string will put the whole program under control of the user. This could then allow a hacker to read other peoples files etc.
    Anyway, that's what is going on. The solution: Make the ping executable setuid-root:
    sudo chmod 4755 /bin/ping
  • k5at
    k5at over 10 years ago in reply to rew
    Thanks.  That fixed the "ping issue"
  • clem57
    clem57 over 10 years ago in reply to k5at
    rpi-update?
  • rdibened
    rdibened over 10 years ago
    You could always execute a "sudo /bin/bash".  Enter your password once and you have a root terminal until you exit the terminal.
  • mconners
    mconners over 10 years ago in reply to rew
    Good call, rew . I didn't even notice that when he did the ls on ping.
    Mike
  • mconners
    mconners over 10 years ago in reply to clem57
    I think he meant the chmod setuid on ping fixed him up, clem57
    Mike
