Raspberry Pi Forum Newer firmware than in debian6-13-04-2012.img ?
  • Replies 14 replies
  • Subscribers 707 subscribers
  • Views 1663 views
I need to take advantage of the latest SD driver code submitted to the RPi firmware:
https://github.com/raspberrypi/firmware
I'm hoping it will help me get my particular SD card to work.
I was using debian6-13-04-2012 and the win32diskimager.
Does anyone know how debian6-13-04-2012.img was built, and how I go about modifying it (or rebuilding it) with the latest firmware?
Mark Bannister.
    e14 Contributor over 14 years ago in reply to Montala
    if you look on the rasPi blog i saw an updater that might work for you.
    Chris, good suggestion, but alas I've exhausted that option already!
    http://www.raspberrypi.org/forum/troubleshooting/how-to-replace-boot-firmware
    Mind you, a helpful chap called Tim says he's solved the problem with the same SDHC that I have.  I've asked him how he updated the firmware on his card, because the steps I think I should take didn't work for me.  We'll see if I get a response to that.
    Ok, I have got it working on Arch Linux and Debian.  So I can confirm that the SanDisk Extreme Pro 16GB SDHC (class 10 card) can be made to work.  Here is how I did it:
    1) I wrote the Arch Linux image to the SD card from Windows using Win32DiskImager.  I could have done this with dd in Linux just the same.  Then safely eject the drives.
    2) I downloaded the latest firmware from github as a ZIP file: https://github.com/raspberrypi/firmware/zipball/master and unzipped it.
    3) I connected the SD card via my USB card reader to my Red Hat Linux VM.  This mounted /media/disk and /media/disk-1.
    4) I copied the necessary files across from the new firmware location:
        # cd <top_level_firmware_source>
        # cp boot/*.bin boot/*.elf boot/*.img /media/disk/.
        # cp /media/disk/arm192_start.elf /media/disk/start.elf
        # cp -R modules/* /media/disk-1/lib/modules/.
        # sync
    5) Safely unmount the media, plug into RPi and power on.
    As a bonus, the latest firmware also fixed the problem I had with regards the display originally being too wide for my widescreen TV.  So all is now well with the world ... I hope these instructions may be of help to someone else.
    Best regards,
    Mark.
    Mark,
      Wow!  that's fantastic that you got it working.
    I think the conventional wisdom was betting against you.
    For example, in this thread:
    http://www.raspberrypi.org/archives/1195#comments
    one poster on May 11 at 9:31am says:
    "There is already a posting from a chap who can’t get his Pi to boot but wants to upgrade the firmware."
    and at 9:49 he says:
    "If a card won’t work in the Pi how would you get the new firmware on it. A sort of Catch 22!"
    The next step may be to do some benchmarking to see if
    the RPi is taking any advantage of the class 10 speed.
    There are some existing benchmarks at:
    http://elinux.org/RPi_VerifiedPeripherals#Benchmarks
    by the way, for anyone else trying to debug their RPi,
    the conventional wisdom is to start with a minimal configuration,
    preferably a working configuration, and add one thing at a time.
    Sort of like playing mastermind, where you get yourself really
    confused if you change multiple pegs in your guess.
    Following that strategy, you would first want to know that your RPi
    worked with a verified SD card, then you would want to know that
    the procedure for updating to the latest firmware worked with that
    same SD card, and then you would try your class 10 card with the
    known working latest firmware.
