Raspberry Pi Forum Raspberry Pi Element 14 Forum->Blog Links
  • Replies 32 replies
  • Subscribers 709 subscribers
  • Views 4913 views
morgaine
morgaine over 14 years ago
This post just provides direct links to the corresponding blog posts of the
Element 14 Raspberry Pi Blog.
___________________________________________________________________________________
2012
February
28
raspberry-pi-a-25-dollar-computer-for-innovation-and-charity
29
openelec-ported-to-raspberry-pi
March
26
raspberry-pi-radio-interview
29
raspberry-pi-latest-status-update
April
03
an-update-on-raspberry-pi-orders-for-brazilian-customers
13
the-raspberry-pi-s-have-arrived
kids-masterclass-with-eben
18
latest-update-on-raspberry-pi-shipments-april-18
27
delivery-update--27th-april
June
05
pi-will-not-boot-up
06
failure-to-accept-login
July
03
review-of-raspberry-pi-images
04
cheap-portable-lcd-for-raspberry-pi
17
look-ma-no-display-using-the-raspberry-pi-serial-console
18
raspbian-based-sd-card-image-released
19
what-time-is-it-adding-a-rtc-to-the-raspberry-pi-via-i2c
22
reviews-experiments-and-other-raspberry-pi-related-stuff
25
headless-raspberry-pi-tell-me-my-ip--text-to-speech-working-for-you
26
is-it-done-yet-temperature-sensing-with-the-raspberry-pi
dynamic-dns--open-up-your-pis-webserver-to-the-world
August
8
raspberry-pi-speaks-1-wire-with-adafruits-occidentalis-image
15
raspberry-in-french
16
raspberry-pi-hdmi-to-vga-converter
20
case-review-6-ip-adelt-case-external-link
September
1
portable-pi
6
we-re-working-with-sony-uk-technology-centre-to-build-raspberry-pi-in-the-uk
7
raspberry-pi-laptop
11
raspberry-pi-lapdock-tricks
12
raspberry-pi-case-wwwmyraspiboxcom
18
brewing-beer-with-raspberry-pi
20
upgrade-to-turbo-mode-without-reflashing
blog-on-interfacing-the-raspberry-pi
26
time-temp-display-for-raspberry-pi
raspberry-pi-meets-open-webos
27
raspberry-pi-lapdock-hdmi-cable-work-around
30
just-another-raspberry-pi-blog
October
1
we-won-a-makey-award
3
play-atari-2600-on-your-raspberry-pi
5
yum-raspberry-pi-a-la-mode-with-an-arduino-on-top
8
fedora-remix-14-for-raspberry-pi-from-seneca
12
we-have-begun-shipping-the-gertboard
16
adafruit-brings-us-raspberry-pi-webide-browser-based-coding
17
raspberry-pi-model-b-512mb-challenge
18
pumpkin-pi-project-for-halloween
20
project-piwriter-aka-the-30lb-notebook
25
a-second-helping-of-pumpkin-pi
beer-can-keyboard-for-the-raspberry-pi
adafruit-and-newark-element14-team-up
November
8
raspberry-pi-good-education-project-out-of-the-box
build-a-raspberry-pi-media-center
14
update-process-to-enable-to-full-512mb-ram
19
my-project-for-double-your-memory-pi-challenge
26
display-tweets-on-a-character-lcd
27
risc-os-for-raspberry-pi-users
30
raspberry-scopi
Morgaine.
NOTES
______
This post just provides direct links to the corresponding blog posts of the Element 14 Raspberry Pi Blog .
It was previously intended to provide direct links to the blog slices, but that doesn't work and has been removed.
Replies in this thread are best avoided (because blog discussions are most appropriate in the blog) unless:
  • You're writing comments/suggestions about these links thermselves or about the thread.
  • You wish to draw forum attention to some new item on the blog, for example RPF reblogs.
  • The topic is meta or cross-cutting, ie. it refers to multiple blog posts, days, months or years.
To avoid promoting some blog entries above others based on my own interests, I'll update this thread with nothing more than "Updated" whenever a new blog post appears, devoid of further comment.  This has the sole purpose of bumping the listing to raise blog visibility.
Comments about individual blog posts should of course be attached to the corresponding blog posts directly.
______
Addendum -- The forum links aren't working properly for blog slice addresses (for example, URLs that select a given month or day).
The actual slice URLs and the blog server addressing are fine --- for example paste "http://www.element14.com/community/community/raspberry-pi/blog/2012/04/13/" into your address bar and it takes you to the desired slice --- but it seems that the forum processing strips blog slice info off the end of blog URLs, eg. the trailing "/2012/04/13/" is stripped off, so all blog slice URLs in the forum end up pointing to the top level of the blog only.
In other words, forum links to blog slices are broken.
Confirmed by looking at the page source.  The forum has set every blog slice link to
href="http://www.element14.com/community/community/raspberry-pi/blog"
I guess this isn't going to work.  Blog slice URLs will have to be off-site, or in your bookmarks. image
Addendum 2 -- Links to individual blog posts are preserved, so those could be listed despite the slice URLs being stripped.
Since blog slice URLs aren't working but blog posts URLs are, I'll remove the slice links altogether and just leave the post links.
I've now deleted the non-working blog slice URLs from the list, so here are some examples to show that they don't work:
http://www.element14.com/community/community/raspberry-pi/blog/2012/04/.
If the blog slice stripping is ever fixed then I'll add the slice links which are omitted from the listing for now.
Addendum 3 -- I may have found a way to overcome the forum slice stripping, testing it now.
Woohoo, the bypass works!  I simply added a '.' onto the end of the blog slice URLs.  As a result I've now changed the months and year into proper slice links.
Addendum 4 -- I regret to say that I can't fix it, folks.  It worked for a while, and then even the nicely working bypass URLs got replaced by the top-level blog URL.  This is being done either by some asynchronous forum processing, or if conspiracy theories are admitted, some human saw my bypass working fine and has now extended the slice stripping to include those ending in '.'.  I can't imagine why anyone would want to do that though so it's not a serious theory --- far more likely it's just a forum bug.
Either way, I'm afraid all the dates/months/years will have to remain as dumb text for now.  Sorry. image
Morgaine.
  • morgaine
    morgaine over 14 years ago in reply to johnsocm
    I list only the entries in Element 14's own Pi blog in my article.  This is just a sort of bridge between the E14 Pi forum and the E14 Pi blog.
    Anyone can write an article for the E14 blog though, so if you pop something in there, I'll list it. image
    Not sure what's actually on your blog (I just see a blank page which is usually a sign of excessive use of Javascript), but from your description it sounds like a useful resource so it would be nice for some of it to appear on the Pi blog here.
  • johnsocm
    johnsocm over 14 years ago in reply to morgaine
    Ok, sounds great thank you!
  • morgaine
    Updated.
    And updated again within minutes to include link of 15th August  which I had previously missed.
  • morgaine
    Updated.
  • ChristyZ
    ChristyZ over 14 years ago in reply to morgaine
    Hi Mortaine,
    I'll have my developers look into the issue with the slice links being stripped out you reported. I know from experience that some of the content types do sometime strip out pieces of urls to other content on the site so we'll take a look and see what we can do about it.
    Thanks for reporting it.
    Chrity
  • morgaine
    morgaine over 14 years ago in reply to ChristyZ
    Thanks Christy! image
    When that's fixed, I'll add slice links for each month to the head article.  For completeness I might also add slice links for each year and for each date on which there is a post, although those slices aren't nearly as useful as the month slices.
    Morgaine.
  • morgaine
    Updated with 3 blog posts.
  • Matt
    Matt over 14 years ago
    Hi Morgaine, I've looked into the issue with blog URLs getting truncated. It's a bug in the core software we use & I've just raised it with the vendor, since it affects their latest version too image We'll see if we can get the official fix back-ported to the version we use here.
    Many thanks,
    Matt.
  • morgaine
    Updated with last 5 links.
  • morgaine
    morgaine over 14 years ago in reply to Matt
    Thanks Matt. image
