Raspberry Pi Forum Still unable to Boot my RPi help please
  • Replies 21 replies
  • Subscribers 709 subscribers
  • Views 2232 views
quitiri
quitiri over 14 years ago
Hi All
I have tried to boot my RPi but without much luck.
I used the win32diskimager to add an o/s to a 4 gig SD card I have tried both the archlinuxarm-13-06-2012 O/S and the 2012-07-15-wheezy-raspbian O/S.
these both gave the same result when i turned on the RPi with the SD card installed i get no video output either on the composite video output or the HDMI output.
I am using a HTC phone PSU charger rated at 5V 1 amp output.
Has anyone got any ideas.
Regards Richard
    e14 Contributor over 14 years ago in reply to quitiri
    Hi Richard,
    Good to see you worked it out.  Can I ask you what sort of display you were connecting to ?  It's been a long time since I saw something that gave absolutely no display with PAL vs NTSC mismatches.
    If you've not found it yet, have a look at http://elinux.org/RPi_config.txt you could add sdtv_mode=2 to config.txt to have the Pi output in PAL.  Lots of other useful stuff in there that might help with getting HDMI working.
