Raspberry Pi Forum How much current can I put into my RPi?
  • Replies 22 replies
  • Subscribers 709 subscribers
  • Views 10531 views
  • amps;
  • current;
  • power;
  • 5v;
  • 5
  • raspberry_pi;
  • volts
  • supply;
  • a;
  • volts;
  • power
  • raspberry;
  • pi;
wallarug
wallarug over 14 years ago
What is the maximum current (supply of) that can go into the RPi before you do serious damage?  Would a 5v 2.1A adapter benefit me in anyway if I am using:
15m Ethernet cable
USB flash drive
mouse + Keyboard
HDMI screen
and have overclock the device to ARM=932MHz/GPU=350MHz/RAM=500MHz
...  Instead of a 5v 1A charger?
  • johnbeetem
    johnbeetem over 13 years ago in reply to wallarug
    Fergus Byrne wrote:
    This is what I mean: [figure]
    Is this what you are also talking about?
    Yes.  You can power a RasPi that way if both of these are true:
    1.  Your USB hub is able to source current through its upstream port.  This is not standard USB hub operation, but some hubs do it anyway.
    2.  Your RasPi's downstream USB port is not protected by a 140 mA polyfuse F1 or F2 because:
    a) It's a rev 2.0 RasPi which does not have F1+F2, or
    b) It's a newer rev 1.0 RasPi which replaces polyfuses F1+F2 with 0 Ohm resistors, or
    c) You have modified an older 1.0 RasPi to short out F1+F2, violating the warranty.
  • wallarug
    wallarug over 13 years ago in reply to johnbeetem
    Thank you fo rthe reply.
