Raspberry Pi Forum Gertboard - The Element14 strikes back
  • Replies 71 replies
  • Subscribers 715 subscribers
  • Views 8800 views
Oh dear. It seems that If I "Fluke PiStalker" want to obtain a Deathstar beating Gertboard from the Element14 Empire. I have to pay £30 quid and then go all "Hands Solo" from "Solder Wars" fame. (if the farce is with my at the time) Thats a big shame really cos I would have paid £40 willinging for one assemmbled by "R2D2" or some other Solder super Driod.
It looks then as if I will have to go remain Fluke PiStalker and wait for a Droid to build me one.
Come on Gert please chase the powers that be to get some assembled versions on the go for poor old guys like me whose idea or circuit assemmbly was screwing and fixing a couple of bits a BakerLite together 60 years ago. image
Seriously Gert a fantastic job great to see them in the wild but we cant all solder however easy it is, Take Pity Darth Gert and sort it for us.
That tale was NOT bought to you by any members of any film companies on the planet Earth. image
Just to keep the balls and games rolling ahead is my target.
Ray
    mcb1 over 13 years ago in reply to Problemchild
    I once purchased a 'Phillips' solder sucker.
    Shorter than others, really good tip, that doesn't fall out, and works better than any other sucker I've found since.
    Another at work agrees and we both wish we could find a source to get some more.
  • morgaine
    morgaine over 13 years ago in reply to mcb1
    Although I have a number of those spring-loaded pump-action suckers, I've never liked that one-shot mode of operation, and have long wished for some kind of continuous suction device.  I guess I could try jury-rigging a vacuum pump with some kind of chamber and filter to prevent solder reaching the pump ...
    e14 Contributor over 13 years ago in reply to Problemchild
    John Alexander wrote:
    But you are right the braid is better than the cheap piston suckers ....grr
    I'd actually disagree with that. At least once you move on from single sided boards that don't have through hole plating. Even the really cheap piston suckers work much better than braid on plated holes.
    Nothing much beats a proper vacuum one though, but even so with SMT parts being the norm mine doesn't get a lot of use.
    e14 Contributor over 13 years ago in reply to morgaine
    Go buy one. You won't regret it. Although the bill for a decent one can be a bit eye watering image
    BTW drew CPC sell some pistol griped desolder tools which although not as good as the several 100£ units are only £50 ish. They truely kick the *** of Solder braid.
    Someone on here asked about one of those cheap duratool ones that both farnell and CPC sell a few months back.  Seems that he hadn't had it very long and the heating element had failed. No spares available and farnell at least had ceased to stock the one he had.
    There's something to be said for getting slightly better branded tools, or ideally the same ones the industry uses. I can still get all the spares for my old weller iron 25+ years on.
    mcb1 over 13 years ago in reply to morgaine
    Morgaine
    Funnily enough there are various models, with various performance.
    One of the best ones was a Denon Instruments (I had a 5000, but the models have moved on) like this http://uk.farnell.com/denon-instruments/sc7000z/desoldering-gun-esd-uk-plug/dp/956880
    The advantage was that the motor was in the handle, which imparted vibration onto the component lead, thereby loosening it and removing solder around it.
    The longer and thinner hot end was easier to get into tight areas, unlike most stations I've seen.
    We have a number of PACE and other types of station at work, and the heat from the accumulated solder in the tube is noticable after 30-40 holes.
    They also don't have the same suction, but if kept clean and filters replaced, will work.
    I do note there are similar types/copies of the Denon available on ebay, but whether you can get parts in several years may be an issue, so buy a few tips, an element and the filters while you can.
    e14 Contributor over 13 years ago in reply to mcb1
    lol... so the farnell price of that sc7000z is 447 GBP, same one on ebay is 715 !
    http://www.ebay.co.uk/itm/DENON-INSTRUMENTS-SC7000Z-DESOLDERING-GUN-STATIC-DISSIP-/350750236538
    the painful part though is that a spare tip for it from farnell is 50 quid image
    So you're absolutely right, get spares while you can, but also factor the cost of spares plus any consumables into your decision
    Somewhat OT, but I've mostly scored ebay off the list as a place to look for anything. In recent years it's changed a lot, a much higher percentage of sellers are businesses, lots of stuff is buy-it-now only and usually is more expensive for a 'bargain'.
  • fuffkin
    fuffkin over 13 years ago in reply to e14 Contributor
    Now, there's the thing. You do find lots of companies selling specialist things on eBay for ridiculous prices. If you were in the market for that solder sucker you'd know what the Farnell & RS price was, so why would you ever buy it at an inflated price? Only an expert (or aspiring expert) would buy this and they would know the normal supply chain.
    I'm seeing so much of this now, I'm beginning to wonder if it isn't some bizarre money-laundering technique.
    Jon
    mcb1 over 13 years ago in reply to fuffkin
    You're both right
    I noted that sometimes the price is soooo much more than larger retailers.
    Funnily enough its cheaper here and Australia (based on current exchange rates), which is not normal.
    You also need to watch the E14 site, as often the same item has two prices, and the difference can be quite a bit.
    Tips are not cheap, but some of the PACE stuff is equally eyewatering, and as long as you keep the temperature right they last a long time.
    Don't be tempted to use drills to clean out the tips, they invariably go sideways ....
    The older Denon model used a glass tube very similar to the smd kit, and you didn't need to buy expensive filters, just a good cleanout.
    I just need to find some data on the pcb for a SC5000. One resistor got cooked and went open circuit.
    Otherwise I might need to invest in new one ... hence the looking lately.
    edit ...found this site but the price with VAT is not much different. http://www.toolshelf.co.uk/Products.asp?MC=4&SC=13
  • morgaine
    Thanks for your advice folks.  Regrettably, I can't justify that kind of money for something I would use so rarely.  It's more cost effective to snip off the device legs, remove the remaining pieces one at a time, and buy a new device!
