Raspberry Pi Forum Introducing PiFace!
  • Replies 14 replies
  • Subscribers 706 subscribers
  • Views 3817 views
Introducing PiFace!
bluescreen
bluescreen over 13 years ago
We are pleased to announce that we're getting ready to offer the amazing new PiFace on element14!
Click here to add your name to the list!
Pi-Face Digital
PiFace (Pi Interface Digital) is a low cost add-on board created specifically for Raspberry Pi. Designed with the same footprint as the Raspberry Pi computer itself, it plugs simply and conveniently onto the top of your Raspberry Pi with no connecting cables needed, allowing you to get started quickly and easily.  Even connecting PiFace Digital to external sensors and actuators is easy, thanks to its screw terminal connectors to the outside world.
PiFace Digital connects your Raspberry Pi to the physical world allowing you to sense and control real physical quantities like temperature, pressure and speed, or even switch states, like whether a door is open or closed.
Using logical programming on your Raspberry Pi that you create yourself, it is possible to define reactions to some of these quantities. For example, you may detect temperature once every five seconds; if the temperature is more than a preset level, switch on a fan.
PiFace Digital is great for educationalists or hobbyists, and for anybody interested in electronics, software or systems control.
Specification
Outputs & Indicators
  • 2 x relays for switching external loads on and off
  • 8 x open collector outputs
  • 8 x LEDs onboard
Inputs & Switches
  • 4 x momentary click switches
  • 8 x digital inputs
Software and API
  • Instant clickable control and graphical feedback
  • Consistent interface for C, Python and Scratch computer languages.
  • Programme debugging aided by instant visual feedback
  • Offline simulator for use whilst developing software without Pi-Face Digital attached.
    bluescreen: As you've specified in your message post: Even connecting PiFace Digital to external sensors and actuators is easy, thanks to its screw terminal connectors to the outside world.
    Can you confirm me that just wiring the sensors to the input and then I'm able to read the values from it? What about the temperature sensors?
    Thanks!
    Thanks!
    Thanks!
    Awesome .. great post love it.. so how do use it ?
