Raspberry Pi Forum The MagPi Magazine - Aimed at learners - Printed edition Kickstarter
  • Replies 62 replies
  • Subscribers 711 subscribers
  • Views 6628 views
bgirardot
bgirardot over 13 years ago
(I have no affiliation with The MagPi Magazine other than happy reader)
The MagPi Magazine is an online magazine dedicated to the Raspberry Pi. It focuses on learning about programmming (Python, Scratch, C/C++) and beginner to intermediate level projects of all sorts.
I have found it to be very approachable for total new comers to programming and hobbiest tools like the Rasbperry Pi and its GPIO pins.
I read a lot of questions that often go along the lines of "I am totally new to programming, where should I start?" and I feel very comfortable telling them to checkout the MagPi magazine among other suggestions.
If you have not checked out the MagPi before, I encourage you to do so, even if it is just so you are familer with yet another resource for the Raspberry Pi community. If you want to learn about programming, I would suggest you just start with Issue #1 and work your way forward.
I, probably like others, sometimes enjoy having a hard copy of project guide to work with. The MagPi is basically on-line only, but they are currently doing a Kickstarter project to produce a printed set of their first 8 issues.
Here is a link to the main MagPi website and if you are interested in getting or supporting the printed editions there is a link to their Kickstarter project:
http://www.themagpi.com/
    michaelkellett over 13 years ago in reply to e14 Contributor
    Motor Drive chips are not that pricey or hard to track down - here's a reasonably novice friendly part in DIP package:
    TI SN754410NEG4, Farnell 9592997, £2.72 each, 384 in stock.
    It does need a 5V logic supply as well as the motor supply but is happy with the 3.3V drive from the RPi - only good for 1A.
    You get quite  abit of protection including what TI call sink/source interlock which stops you from turning top and bottom devices on the same side on at the same time.
    Michael Kellett
  • GreenYamo
    GreenYamo over 13 years ago
    I hate to be so negative, but the writing in this magazine seems to be getting worse. I have read every one so far, but in the most recent one there seems to be a number of things that just leave the user hanging or have obviously been written by someone who is an expert in what they are doing, but can't convey that information properly to a beginner.
    I did look at the Kickstarter on this, but couldn't justify it on the grounds that better information is either available freely on the web, or via one of the many books popping up recently that are cheaper than the bound set of these magazines.
    I was however happy to see the Ciseco Eve Kickstarter get funded and I have my board from them already :-)
    Steve
  • gdstew
    gdstew over 13 years ago in reply to GreenYamo
    Yea it's not like you have a history of that in Rapberri Pi forums or anything. Oh, wait a minute.
    John Beetem wrote: You can have upper NPN drivers provided that you can get the base voltage higher than the emitter voltage.  The L298 diagram doesn't show the details of the AND gates that drive the upper NPNs.  I suspect they convert TTL input levels to "Vs".
    You're right. I found a data sheet for the L293 and the first stage transistors on the motor drivers are tied to the motor supply.
  • bgirardot
    I bet they would be glad to get a follow up "letter to the editor" type communication that discusses a previous article. Lots of magazines have a letters section that reference and discuss a previous issue's articles.
    This has been over my head, but even for someone at my level, the discussion has been educational.
  • GreenYamo
    GreenYamo over 13 years ago in reply to gdstew
    Another fan of my work :-)
    The thing is, what gap is this magazine filling ? None as far as I can see. Taking the 'H' bridge article above, I can't see what it is supposed to add. At the end of the article, it goes on to say that next edition, there will be another way to drive a motor with cheaper transistors etc. So in the mean time, do I wait or just hit google and work it out for myself with the myriad of resources available on line. Will next month it illustrate something else and the go on to promise and even better method the next month? At least in the days of Spectrum User, you got a complete program to type in (albeit with printing errors to make it that bit more interesting!) so you could have some gratification there.
    Also, i'm not sure what the point is of doing two articles on programming languages (Cecil and ADA) that are hardly in the sphere that the Pi is aimed at. That smacks to me of padding out.
    So, do I take my £25 and get 8 whole copies of a magazine that stretches to about 32 sides an issue, or do I spend that on another Pi, or do I spend it on one of the many interfacing options springing up and a good book - these should provide immediate reward and be a much better prospect in the long run.
    It is something that can be levelled at most magazines now, which is why I don't buy any. I also object to the large amount of coverage the Foundation have given them when there are countless other people working away on different projects that hardly get a mention. It's been the same with the Pibow people too, massive amounts of coverage and 'Oh look, our kickstater is funded'
  • johnbeetem
    johnbeetem over 13 years ago in reply to GreenYamo
    Steve Read wrote:
    The thing is, what gap is this magazine filling?  None as far as I can see.  Taking the 'H' bridge article above, I can't see what it is supposed to add.  At the end of the article, it goes on to say that next edition, there will be another way to drive a motor with cheaper transistors etc.  So in the mean time, do I wait or just hit Google and work it out for myself with the myriad of resources available on line.
    JMO/YMMV:
    I haven't read MagPi Magazine myself, but I've read good reviews of it.  Its audience is new RasPi users who don't have strong technical backgrounds and don't know where to start.  Old timers like yours truly are excited by RasPi because of its ridiculously low cost for a GNU/Linux "box" and we know what can be done with such a board: basically the same things we did with $295 boards five years ago, but now the penalty for smoking a board is the cost of a good dinner.  But we're not the official RPF target audience.  The target audience is young pups who don't know what they're doing but have boundless enthusiasm and "Insatiable Curiosity, which means they ask ever so many questions" [Kipling].
    MagPi is a way to get them started.  Like all magazines and wikis that depend on unpaid contributors, quality varies and at some point a magazine needs to decide if it should follow a strict periodic publication schedule or only publish when they have something worth saying.  Personally, I find most printed matter becomes obsolete pretty quickly and a well-edited wiki with an enthusiastic community behind it is a much better use of 21st Century resources.
    Googling things is problematic.  If you know exactly what you're looking for and have enough knowledge to filter out the high noise content it can be very effective.  If you're a newbie, it's hit and miss -- mostly miss.  I generally start tech searches with Wikipedia, which often has excellent technical information though not always -- quality depends on whether there's someone (preferably plural) fanatically interesting in the topic who takes the time to polish the article.  I go to Wikipedia to fill in gaps in my knowledge, not to learn something big like logic design or circuit theory from scratch.
    shabaz over 13 years ago in reply to johnbeetem
    I haven't looked at it much, but in general as a suggestion maybe they need to get the magazine and any blog content vetted by someone senior before they publish. I've just spotted on the raspberrypi.org site that someone has published a relay controller connected to mains, but the creepage (?) distance is less than a millimeter on the stripboard between the relay switch COM pin to the ULN2003A ic (left unsoldered on the stripboard). I only noticed this because I've used a similar relay pinout in the past. I would respond but I don't think I've ever registered at their site. I will  leave a comment on the linked blog however (here), maybe the author can indicate it is not for mains.
  • bgirardot
    bgirardot over 13 years ago in reply to GreenYamo
    I think it fills the niche of people who like things in a magazine format. For sure people are doing great things on blogs and on YouTube as well. I personally have not seen the foundation pushing The MagPi especially hard, but I only read the RPi forums, not their blog or follow their in person goings on or other media they do. But I wouldn't be surprised if they did, it seemingly holds some weight to say "There is a magazine dedicated to our product" even if it is nothing more than a differently formatted type of blog.
    As to the wiki, unfortunately, with the unofficial, but still definitive RPi wiki, it is very out of date in many areas. It seems about the last thing people do is decide to go back and edit the wiki when things change and there is certainly a dedicated community around the RPi so I do not think that is the part that is lacking. My main reason for not editing the wiki much is that I feel I am not qualified to edit what is essentially a definitive source of information.
  • bgirardot
    bgirardot over 13 years ago in reply to shabaz
    Please do register for the forums and contribute, especially information you feel is important. The forums are one of the main places people look for information as far as I can tell. I for one post on there for no other reason than to get feedback from better informed folks like yourself, it is really helpful.
    shabaz over 13 years ago in reply to bgirardot
    I've left a comment on the blog and also just tried the raspberrypi.org, it seems I only needed to write a name and e-mail address. I don't see it published, but I guess it is moderated first.
