Raspberry Pi Forum The MagPi Magazine - Aimed at learners - Printed edition Kickstarter
  • Replies 62 replies
  • Subscribers 711 subscribers
  • Views 6677 views
bgirardot
bgirardot over 13 years ago
(I have no affiliation with The MagPi Magazine other than happy reader)
The MagPi Magazine is an online magazine dedicated to the Raspberry Pi. It focuses on learning about programmming (Python, Scratch, C/C++) and beginner to intermediate level projects of all sorts.
I have found it to be very approachable for total new comers to programming and hobbiest tools like the Rasbperry Pi and its GPIO pins.
I read a lot of questions that often go along the lines of "I am totally new to programming, where should I start?" and I feel very comfortable telling them to checkout the MagPi magazine among other suggestions.
If you have not checked out the MagPi before, I encourage you to do so, even if it is just so you are familer with yet another resource for the Raspberry Pi community. If you want to learn about programming, I would suggest you just start with Issue #1 and work your way forward.
I, probably like others, sometimes enjoy having a hard copy of project guide to work with. The MagPi is basically on-line only, but they are currently doing a Kickstarter project to produce a printed set of their first 8 issues.
Here is a link to the main MagPi website and if you are interested in getting or supporting the printed editions there is a link to their Kickstarter project:
http://www.themagpi.com/
  • GreenYamo
    GreenYamo over 13 years ago in reply to e14 Contributor
    Hi coder,
    Yes, didn't explain myself well there. Completely agree that programming is very squarely in the market that the pi is aimed at, but not sure that two fairly unusual languages would serve that purpose well, at least for people starting out with the pi and programming.
    Mind you,I remember playing around with Prolog on my Spectrum many years ago, so what do I know :-)
    You mention Jerry Pournelle - love it when he is a guest on Leo Laporte's podcasts. He is such an amazing person.
    Steve
    e14 Contributor over 13 years ago in reply to GreenYamo
    Hi Steve,
    I still disagree, even with your clarification.
    If the MagPi editors were pushing Ada and Cecil as "the one true way"
    to program your RPi, then sure, those languages are too obscure to be
    pushed that hard.  But it seems clear that they are promoting Python,
    Scratch, C++, etc as mainstream languages, with Ada and Cecil
    touted as just interesting languages you can use on your RPi.  So the
    obscurity doesn't bother me at all.  Pretty much any language has
    interesting features that are worthwhile for student programmers to
    learn about.
    By the way, Ada isn't nearly as uncommon as you might think.
    Its application domain of large-scale embedded systems, primarily
    in aerospace and defense hasn't grown nearly as fast as other
    domains such as smart phones and web programming, but is
    still quite large, and compiler support is quite good.  Ada is also
    relevant historically as the basis for VHDL, and has had significant
    influence on other languages such as C++ and Java.
  • GreenYamo
    Hi Coder,
    Having thought about it, I guess I'm coming round to your way of thinking. It's hardly like they are pushing Ada or Cecil as the languages at the forefront of Pi programming and it is always good to learn about new ways of doing things.
    Perhaps I should look at the Cecil article again and give it a bash !
    Steve
    Steve,
    exactly!  Here are some concrete examples.
    In Fortran 66, like in assembly language, the only control structures
    available are the goto, conditional goto, and subroutine call.  Later,
    languages such as C and Pascal popularized "structured programming" with
    higher level control structures such as if/then/else and do-while/repeat-until
    loops.  The main advantage of these control structures is that when
    reading a particular line of code, it's always clear how you must have
    gotten to that line, because "spaghetti code" with arbitrary forward and
    backward jumps isn't allowed.
    Fortran users didn't need to switch to C or Pascal to take advantage of
    this concept.  They could continue to use Fortran, but with preprocessors
    such as Ratfor, or even without using a preprocessor, they could
    simply make disciplined use of goto's.
    In the 80's, modular languages became popular, with separation of
    interface from implementation, for much the same reason.  When
    you are reading code in a module, you want to know that you could
    only have entered the module through one of the subroutines in the
    module's interface.  This discipline can be practiced in any language,
    even if the language does not enforce it.
    With the popularity of object-oriented concepts such as inheritance
    and dynamic dispatching, it is possible to use those concepts in
    languages such as C that don't provide any direct support, but do
    allow indirect subroutine calls.
  • johnbeetem
    johnbeetem over 13 years ago in reply to e14 Contributor
    coder27 wrote:
    Steve,
            DO 10 I=1,100
    10    WRITE(6,20)
    20    FORMAT(27HYOU FORGOT THE DO STATEMENT)
            STOP
    I should also pick on you for not mentioning computed GOTO and assigned GOTO image
    coder27 wrote:
    Later, languages such as C and Pascal popularized "structured programming" with
    gotten to that line, because "spagetti code" with arbitrary forward and
    Structured programming constructs were already popular from the time of Algol 60, but primarily among computer scientists.  Fortran programmers viewed them with suspicion and claimed they optimized poorly.
    C and Pascal frown on using gotos, but provide them in the language so it's still possible to write spaghetti code.  It's also possible to move spaghetti logic to the conditional flags of the the form "while not found and not error do begin {bunch of nested hard-to-follow logic} end".  Handling error conditions is often much easier to follow using a goto as an exception.
    It's also worth mentioning that at the time of Fortran 66 and Algol 60 it was common practice to flowchart your program before coding it, so the structure was clear despite gotos.  Much easier to tell if there's spaghetti logic or other wooly thinking with a flowchart.  It was also standard practice to hand-check programs before submitting card decks since turn-around was too slow to permit hacking.
    JMO/YMMV
    e14 Contributor over 13 years ago in reply to johnbeetem
    JMO/YMMV
    Flowchart use is still very much standard practice here - possibly because I have a head like a sieve! The influence of BASIC can still be felt here 30-odd years on...
    Perhaps modular programming will really come of age when all we have to do is draw a flowchart and our friendly compiler will burp out the code for us. Heresy perhaps, but I'm not a subscriber to the "it's supposed to be hard, dummy" whatnot. We'll still need a few smart folks to write the compilers, after all. Life's too short to learn proper code and be creative! image
    John,
      Good points.  I was really sloppy forgetting to mention Fortran's Do loops,
    which were there from the beginning.  But Fortran, along with Cobol and Basic
    took a long time to adopt the if/then/else and while-loop constructs that are now
    considered fundamental, although enlightened and disciplined programmers can
    avoid writing spaghetti code in any language.
    Fortran creator John Backus is quoted as saying: "we did not regard language
    design as a difficult problem, but merely a prelude to the real problem: designing
    a compiler which could produce efficient programs."
    Of course, now the tables have turned, and efficiency is no longer a major concern
    for most programming languages, but language design is considered a difficult problem.
    Jonathan,
    I'm not sure exactly what you meant.  Some people think there is a conflict
    between creative programming and disciplined programming, but I don't.
    Some people think time spent coding is important, but usually it is far
    outweighed by later phases of the software lifecycle, including testing,
    debugging, maintenance, and enhancements.  Taking an enlightened
    and disciplined approach to code writing can more than pay for itself in
    the later phases.
    Ludwig Wittgenstein wrote: "The limits of my language means the limits
    of my world."  I think that's applicable to programming languages too.
    coder27 wrote:
    Jonathan,
    the later phases.
    Well... You're absolutely right in that the actual coding is only a small part of the whole conceive -> write -> tweak iterative thinger, but:
    some people are just plain better at dreaming up an effective original concept and others may be better at the discipline of turning it into code. Another person still may be better suited to testing every possible combination of user situations in order to shake out bugs in a repeatable manner, document them clearly and suggest ways in which workflow could be improved with regard to the ordinary mortals who will be the end users (coders are by no means ordinary mortals).
    I don't think that this concept is anything new. It possibly started around the time when two cavemen (one of whom was good at knapping arrow heads but couldn't run very fast, while the other was a talented hunter who hated spending his evenings chipping away at lumps of flint) decided to cut a deal regarding the division of labour and mammoth steaks. Perhaps Open Source v2.0 will be more collaboration / barter friendly - because we can't all excel in every discipline and so there's a lot of talent going to waste out there. But if Open Source can't figure out a way to get people with complementary skills together (and given that the bits of the web dedicated to Open Source seem to be stuck forever in the 1990's) then programming will have to become more intuitive. It'll be the same unambiguous language(s) underneath, but wirapped in a smarter interpretation shell. Why teach a million people to think like machines when you can build one machine that can think for itself, just a little?
    It'll never catch on, of course. Nobody wants to knock down the Tower of Babel. image
    Really??  I think everyone is disgusted by the folly of
    umpteen different ways to say the same basic thing, such as
    http://brianary.blogspot.com/2011/02/then-what-elif-elsif-elseif-or-else-if.html
