Raspberry Pi Forum jack & full duplex possible
  • Replies 22 replies
  • Subscribers 705 subscribers
  • Views 3444 views
Hi all,
I was wondering if it's possible to use Jack?
If yes, is full duplex (in & out) possible?
What can I expect for the latency (less than 20ms, more than 100 ms)?
If not, with Alsa is it possible to have analog in & analog out working at the same time?
Off-topic:
Some people are talking about this distribution that is featuring low latency / jack solution:
https://ccrma.stanford.edu/~eberdahl/Satellite/
    Hi Pat,
    next weekend there will be more information on how to compile the 3.12 kernel with rt-preemption and wolfson drivers included on my website. Please be patient and
    Have fun.
    Here we go:
    http://blog.georgmill.de/2014/04/26/compile-wolfson-audio-card-driver-for-kernel-3-12-y/
    Have fun.
    I have problem:
    git reset --hard 4639d2b773b318d4b0409f67d3d5e73a513ba64b
    fatal: Could not parse object '4639d2b773b318d4b0409f67d3d5e73a513ba64b'.
    Hi Georg!
    Thank you so much for this. Will try to find the time asap to confirm that it's working. With your permission, I will upload the rt-kernel with module so that people can simply do Step 53 (or maybe you already share the files somewhere)?
    Talk to you soon
    @ Jan Tomasik
    Hi Jan,
    what does
    git status
    say?
    Georg
    I tried both, of course, it's always the same:
    the object does not exist.
    git status
    # On branch rpi-3.12.y
    nothing to commit (working directory clean)
    Hi Jan,
    you are right. Maybe I made a mistake with git and now have the gravity (movie) effect: Detached sources and lost in space? ;-)
    Hope there is time enough to find a solution for that soon. I'll let you know.
    Georg (without having fun)
    Hi Jan,
    please have a look at http://blog.georgmill.de/2014/04/29/compile-wolfson-audio-card-driver-for-kernel-3-12-y-a-new-try/
    Test and report,  please. Here I'm able to use the Wolfson card full duplex with jackd and calf-plugins. I routed the two onboard mics through calf reverb and then trough calf phaser to system playback. What an echooooooooo ;-)
    With much more fun than ever !
    Many thanks Georg
    I used your kernel source code to create patch for Runeaudio with Wolfson Audio Card and Power-on-off circuit.
    The only problem is in boot with "vc_cma: dma_declare_contiguous (11800000, d400000) failed", I used the workaround described in http://archlinuxarm.org/forum/viewtopic.php?f=31&t=6432
    Otherwise, it works great, thanks for the great work.
    Re: Instructions for compiling the wolfson audio card kernel drivers and supported use cases
    Hi Georg,
    So sorry. I am pretty new to Linux and the RPi. Is there a benefit to using your method over just flashing my pi with Wolfson's distro of raspbian with the drivers already installed? I understand by cross compiling the kernel, you can add the Wolfson drivers to an existing distro that you have on your RPi, but I am a new user. Am I better off just using Wolfson's prepackaged distribution? I want to use JACK on a headless setup for an audio FX unit. I will be writing the .cpp files using JACK's process callback. Thank you so much for your help
    -Rob
