Raspberry Pi Forum microphones and the cirrus audio card
  • Replies 30 replies
  • Subscribers 708 subscribers
  • Views 4001 views
  • wolfson
  • cirrus
  • recording
  • raspeberry_pi_accessories
  • microphones
soundcamp
soundcamp over 11 years ago
I want to use stereo electret condenser microphones with this card. They need a a bias voltage (Plug in Power) of around 5V.
The Wolfson only included mono microphone support through the Mic in plug.
The comparison table for the Cirrus says it supports stereo microphones through the Line in, and the video introduction to the card mentions that bias voltage is provided for electret condenser microphones, but doesn't give more detail.
It would be great to have confirmation of what exactly this card provides in this direction.
This is important because it decides if the card enables the Pi to be used as a high quality audio recorder without an additional soundcard - as the Wolfson sadly could not.
Grant (soundCamp)
  • binauralhead
    binauralhead over 11 years ago in reply to soundcamp
    I would be very happy if you could let me know how you managed to do this.
    I've purchased the card, and for the life of me can't get it to work with Darkice/Icecast2.
    Wanted to use Darkice and Icecast2 for streaming live binaural audio to a on-line radio web server (working on my other Raspberry Pi and Behringer UCA202)
    Just that the Behringer is a tad noisy, hoping the Cirrus card is much less noise floor.
    Wanting to stream MP3 live audio from the cirrus card through to a 3G mobile network here in the UK.
    Regards
  • soundcamp
    soundcamp over 11 years ago in reply to binauralhead
    Hi Alan
    We found it's a little tricky compiling Darkice over the Cirrus Logic image. We will make a disk image available over the next couple of days and let you know
    bw
    grant
  • binauralhead
    Thanks for letting me know that you are on the case Grant.
    Looking forward in hearing from you.
    Regards
    Alan
  • soundcamp
    Hi Alan and all
    We have a disk image that streams stereo audio using Darkice and the Cirrus Logic Card with Pi B+ or A+. It uses the Line In with bias voltage by dafault, and has been working well with electret condenser microphones.
    It is available to download with notes from the soundCamp resources page here (where there are also images for the Wolfson and other setups)
    Best wishes
    Grant (soundCamp)
  • binauralhead
    Great stuff Grant, one problem!
    I need another 734PB of disk space to extract.. tried downloading twice, must be corrupt, same result.
    Will try later this evening.
    Regards
    Alan
  • soundcamp
    Hi Alan
    Thanks for picking that up.
    I'll check it out and see what's going on
    bw
    grant
  • soundcamp
    soundcamp over 11 years ago in reply to soundcamp
    Hi Alan and all
    We have uploaded a verified new disk image to  the soundCamp resources page
    soundCamp resources - Pi SD Card - Download
    I hope that will work fine now
    Let me know if you have any other issues
    bw
    grant
  • binauralhead
    Hi Grant,
    Thank you for your hard work, and to the others who are working on this cirrus logic audio card too.
    I've tried the new image, it works, I've managed to stream on the test stream, there's a little interference coming through a "buzzz" which changes as you move the card and wires about, you can get it so that it is almost gone too.
    Not sure if it has to get to the GUI? Would have liked headless, I've tried turning off the GUI but it's got some script running for the IP which stalls the command line. Changing the host name breaks some things too.
    I'm confused as how darkice works without Icecast2.
    My new account for the testing microphone site breaks the streaming as well, not sure why, there is a conflict of terms in the conf file to the information given after new account conformations.. being a fair newbie probably isn't helping me comprehend what is going on in that config file.
    Was hoping to run SAMBA, WEB Server, noip ddns client, sakis3g, Icecast2 and stream to another online server, though I am quite interested with the microphone radio site, as it works on "switch on", so why not use this without me faffing about trying to get other things to work when not needed? probably the challenge! but an easy excuse not to try.
    I hope to have some answers from the help guys on the microphone site, so with luck will have "Liverpool_3D_binaural" sound stream up and running soon.
    I am so grateful for those who have worked hard to get things going, thank you very much guys!
    Regards
    Alan
  • soundcamp
    Hi Alan and all
    I'm glad the disk image has been useful to get started. I will check how to disable the automatic darkice script to make it easier to work with.
    I'm sorry that realistically I won't be able to provide much detailed advice and support on applying the card to other uses - although I am happy if it is contributes to those.
    I should also be clear about some limits to its use:
    This disk image is designed specifically as an approach for live audio streaming to the Locus Sonus open microphone soundmap.
    The notes etc on the soundCamp resources page are also aimed at that.
    The soundmap itself is a specific project, with specific parameters, described here http://locusonus.org/ -Locustream
    It's a long standing project (not mine), and isn't intended to include eg conventional radio material, recordings, musical performance, etc
    So if people are experimenting with the disk image, beyond preliminary testing, you should alter the stream configuration file to point at your own icecast server (which you could also set up on a local machine).
    Please use the disk image for your own projects as useful.
    But please don't use the Locus Sonus server for general experimentation.
    I should have been clearer about that when I shared the link.
    Best wishes
    Grant
  • binauralhead
    Hello Grant, et al..
    The thought of "this could get interesting" came to mind when I realised that with a fresh image, network connection and power on, you would be streaming, if it were to be popular to download ...... When I realised this, I was very conscious of being switched on, and on-line - hence my swift move.
    "The soundmap itself is a specific project, with specific parameters, described here http://locusonus.org/ -Locustream
    It's a long standing project (not mine), and isn't intended to include eg conventional radio material, recordings, musical performance, etc"
    This sounds like the perfect place for my binaural microphones!! This is very much NOT a conventional way to record things or to have streaming live, and is something I have been looking for many months. If anyone cares to have a listen to any of my binaural recordings, and see what "Frank the terrorist" has been upto please wear your best headphones and click here: https://soundcloud.com/binauralhead you can also see what I have been up to on the blog, address is on the soundcloud channel, if you read the full profile on "Frank".
    Having the raspberry Pi in a bag (or anywhere), with battery and 3G/4G dongle and a "binaural microphone" .. would, for me, be quite something, esp if there was a dedicated website that had many binaural microphones placed about the globe, to experience being there would be totally awesome. Unless you have experienced listening with headphones what binaural audio is, you will have no idea what I am on about.
    If it were not for people like Grant, and the people who are doing the microphone project, I would not be so excited with this idea, and it would probably never have happened for me. In the last 12 months of being interested with binaural audio I have met, quite by chance, some very famous people, and been to famous film studios with both my dummy head microphones - all were totally awesome experiences!!
    Being able to listen to an audio stream that has very good quality, live (or recorded) from your iPhone, MAC or PC, Library or on-line radio station is just as good, if not better than 3D vision! and if combined...
    I feel that something very good could come of this, and if not, it's something that keeps me interested with sound, the raspberry pi, and new people to talk with, who could want for anything more?
    Slice of Pi anyone?
    Regards
    Alan
