Raspberry Pi Forum rpi2 not working with my old CRT TV
  • Replies 18 replies
  • Subscribers 706 subscribers
  • Views 2751 views
  • video
  • composit
Hi, I am from India and recently I brought my first RPI2 mode b (1GB) RAM version, and when I connect my PI2 to CRT tv using RCA cable I am not seeing any out put I tried with multiple images (NOOBS,Raspbian.....) after lot of search in google, I have followed following changes.
https://bhavyanshu.me/tutorials/force-raspberry-pi-output-to-composite-video-instead-of-hdmi/03/03/2014/
Still, it's not working can any one help me please. I am using LG slimmagic CRT TV.
    When I change the input, I can only see AV2 on top right corner nothing else completely black screen and when I change mode(TV/AV) using remote I can see other modes like AV1, Component and S-Video.
    You're welcome.
    Strange that it goes from TV to AV2.  I have found with some manufacturers that you have to select an AVx input, rather than Component.  Have you tried powering your RPi up and running through all the input modes on the TV?  I would even go so far as to leave the audio conns unplugged.  That shouldn't make a difference, but I've seen some few CRT sets that ended up with grounding problems when the audio was plugged in.
    Hi, when I loosen the 3.5 mm jack I can see booting and Rasp logo,  but it's flickering it's difficult to make out something.
    -Nageswara
  • clem57
    0 clem57 over 11 years ago in reply to e14 Contributor
    Ah. That says the GND is the sleeve and not the next first ring. You cannot use this cable and must get a cable with GND on the ring. You have a video composite cable which does not work.
    C
    As Clem points out there might be a cable problem, but the link to the cable you have above shows the correct configuration.  I'm wondering if you don't have a problem with the ground on the socket.  The gold ground inside the socket is a tension bar.  It can get flattened or pushed back so the connection isn't good electrically.  Check the placement against the socket in the picture for reference.  For electrical sockets with this type of ground I usually use the end of the barrel of a ball point pen to gently pull the bar up.  You don't want to push it back or deform it, and this way usually prevents that.
    Thanks Brian Edwards, will try this today and let you know what happened.
    No luck still it's not working image
    All the more reason to consider my previous suggestion: use a normal HDMI cable with an adapter -or- get a cross-over cable -or- DIY cable.
