Raspberry Pi Forum Mass storage emulation raspberry pi
  • Replies 12 replies
  • Subscribers 707 subscribers
  • Views 4123 views
I have a device developed by a third party that generates a report when requested.
The output of the report is a text file. The device is it is only capable of writing to a USB drive.
I am trying to figure out the best way to automatically print the report after it is generated.
I have found a good thermal printer I can use with a raspberry pi. But I'm not seeing a great solution to make the pi emulate a USB drive allowing this machine to output to the PIs native storage.
I'm wonder if anyone has a suggestion to make this work. Weather it use the raspberry pi or another board.
    0 e14 Contributor over 10 years ago in reply to rew
    These are very good points I'll have to monitor the file name creating and the write operation time.
    I will probably just run a cron job every second or so.  When it sees a file name wait 4 seconds for the write to complete then start printing. (actual timing to be determined.)
    I should be able to just do a purge of all the files at the end of the day when no one is using the equipment anymore the text files take up very little space so i can hold on to a day's worth I'm sure.  Then maybe I can reboot the device and delete the files on startup.
  • rew
    0 rew over 10 years ago in reply to e14 Contributor
    Linux normally caches stuff for disks up to 30 seconds before starting to write to the device. I think this is shorter for external/removable devices. If your third party device works the same way, that 4 seconds may indeed be enough.
    This weekend I started logging my electricity meter data into a database. It's running on a pi-zero. Extrapolating from a days worth of data, 10Gb of my SD card can hold 20 years of ALL the data that the meter produces!
    So.. In your case, I wouldn't be in  a hurry to remove the files. Just note somewhere which ones have already been handled.
