Raspberry Pi Forum how to use serial port in raspberry pi 3
  • Replies 24 replies
  • Answers 6 answers
  • Subscribers 708 subscribers
  • Views 7571 views
prasadjain05
prasadjain05 over 10 years ago
i had try so many code and thing but i dont get the correct answer for how to transmitter or receive the data through GPIO pin of serial port
  • rew
    0 rew over 10 years ago in reply to oksbwn
    No you're not aware of that.... raspi-config will DISABLE the serial port altogether by putting enable-serial=0 in the config file for you. Then you can no longer access the serial port hardware from the ARM side. As far as Linux is concerned the hardware has been unplugged. No "now your application can access it".
  • oksbwn
    0 oksbwn over 10 years ago in reply to rew
    This is where you need to make it 'No' . Now any application running on your Raspberry Pi can Access the Serial Port
    And this is  "enable_uart=0" Instead of "enable_serial=0" what u have mentioned. Please check.
    And this works 100% with JAVA and Pi4J
  • prasadjain05
    0 prasadjain05 over 10 years ago in reply to oksbwn
    i had disable the login shell but i dont get idea how to send the data on serial port which is present on board if you can tel me how to send or receive message through UART in Rasberry pi 3
  • oksbwn
    0 oksbwn over 10 years ago in reply to prasadjain05
    After that you can use any programming language to access the serial port depending upon what you are comfortable with.  I have not used python but have used with JAVA with Pi4J Library.
    Just google for Pi4J and that comes with a lot of descent examples.
    To run java application on Pi . If you are interested to give it a try you can go through my tutorial
    https://www.youtube.com/watch?v=kNvLRDpduYs
  • prasadjain05
    your tutorial is good but you have not send that "hello world " over serial port i want to send it over serial port could you help me with it
  • oksbwn
    Ya sure....That video was not about serial port....I can help with that......But with JAVA only...
  • prasadjain05
    ok assist me for the java i can code in java
  • oksbwn
    Ok then download The Pi4J Project - Download
    and add it to your project. The downloaded zip folder contains nice examples for serial communication.
    If you can wait i am working on some tutorials around Pi4j which will be online before next week...
  • clem57
    0 clem57 over 10 years ago in reply to oksbwn
    Cool -> The Pi4J Project - Usage (Serial com over com port).
    C
  • oksbwn
    0 oksbwn over 10 years ago in reply to clem57
    Ya..
