Raspberry Pi Forum Learning Electronics need Basic Test Equipment.
  • Replies 19 replies
  • Answers 3 answers
  • Subscribers 710 subscribers
  • Views 3151 views
  • test equipment
  • frontpage
  • learning
  • electronics
I would like to get into learning about electronics and repair.
Can someone recommend some decent/cheap basic test equipment to get me started?
Specifically I have never used an oscilloscope but would like to learn. I know there are
analog and digital ones. I would like to be able to diagnose and repair small electronics
like headsets, video games, etc.
William
  • uscdadnyc
    0 uscdadnyc over 10 years ago
    USCDADNYC's Credo(s) are:(a) KISS Keep It Simple Stupid, (b) WFM Works For Me, (c) WWIYCR Why Walk If You Can Ride, (d)IIIFIIFM If It Is For Free It Is For Me. The professional Engineers out their will scoff at my suggestion. That WT (Original Poster) get what I just had gotten for my B-Day. I mentioned it b/f here at element14 on another Blog Thread. GET (a) RaspPi 3 (b) 7" RaspPi Touchscreen (c) SmartPi Touch Case (get the one w/ Lego Noobs), (d) A USB Bitscope. I am going to use my Dremel Tool to cut out Access to the HDMI Port in this case. And use an upward Right-Angle HDMI Adapter (Male-to Female). BTW the way I soldered the wires from 7" Display it is Easy to open the case expose the uSDcard on the RaspPi 3 and change out uSDcard and run Minibian via the Putty s/w (a SSH client). Here NO (keybd, mouse or even Monitor [like HDMI]) are even Used. You can manipulate the GPIO pins which are available in this Case's already formed Cut-out Slot.
    So, w/ this setup one can: (a) use as Bitscope, (b)Touch Screen  RaspPi , (c) Run RaspPi as a Computer (run Python, or Wolfram Mathematica,etc), (d) as a controller of RaspPi GPIO Pins via Miniban.
    Such a Deal. I Know that the Freq Response of the Bitscope is only 20MHz, But at this stage, for WT, It might be sufficient. I know it is SEXY to have all sorts of Elaborate Test Equipment, But I turn 65 years Old Today, and running simulations on my Student Copy of MatLab/SimuLink is more Sexy to me.
  • clem57
    0 clem57 over 10 years ago in reply to uscdadnyc
    Happy 65th time around the Sun!
    Clem
  • bprewit
    0 bprewit over 10 years ago
    Hi, William:
    I was lucky enough to have Uncle Sam send me to electronics school .. but here's my take:
    The first thing that you need isn't an o-scope; it's a voltmeter.  Learn to use it to check voltages & continuity first; that'll actually enable you to handle ~ 80% of repair tasks.
    You can obtain a perfectly good voltmeter from your local home-improvement superstore for < $100.00 .. head out to your local electronic supply house (or order) a potentiometer & battery, study Ohm's law, figure out how to demonstrate using battery, pot,  & voltmeter.  Mastering this will get you well on your way.
    Once you understand DC circuits, then you can start to look at AC circuits .. that's when you will need an O-Scope.  Until then, it's just an expensive paperweight.
    I'm looking for a course to recommend to you but so far haven't seen anything.  If I find something, I'll let you know.
    0 e14 Contributor over 10 years ago in reply to bprewit
    Hi Bruce,
    I have a cheap multi-meter, I also have a fluke multi-meter if I could ever find what box I stuck it in when we moved. image
    Unfortunately besides Radio Shack (which doesn't really count) we don't have a local electronics store around here any more. I have ordered stuff before from digikey,
    but maybe there is a site that doesn't require such bulk orders.
    If you can find a course to recommend that would be great. I'm also looking around. I learn better from videos and hands on then books.
    William
  • bprewit
    0 bprewit over 10 years ago in reply to e14 Contributor
    Nothing wrong with Radio Shack .. I think I have at least one of everything on their back wall!!
    Get a 10K pot, look at Wikipedia entry for Ohm's Law, hook it up & see how it works.
    I'm still looking for a good starter course; I'll let you know if I find one .. but you can start by just experimenting!
    Bruce
  • uscdadnyc
    0 uscdadnyc over 10 years ago in reply to bprewit
    For Courses  (Electronics, Electricity,..) Try YouTube. They is even one (or Two) about Setting up an Electronics Test Bench. Then there are MOOCs (Massively Open Online Courses). Such as edx.edu, coursera.org, lynda.com(?),udemy.com. The last two I believe are For-Profit Sites. IDK about lynda, but udemy is pretty good and is affordable. Udemy is the best of the MOOC providers, for H/W & (their) Associated S/W. Ex: TI (Texas Instruments) uController H/W that Courses use for example C++(?) as the programming language.
    As for Physical electronics Parts, some Micro Center (physical) Stores in the USA, carry "piece" parts.
    Again I ask Comment(ers) to sign-off your Remarks w/ an indication of their Physical Location
    For Ex: USCDADNYC (NY NY USA)
  • the-dubster
    0 the-dubster over 10 years ago in reply to bprewit
    Bruce, similar situation here, except in the UK it was Autie Betty Windsor who taught me how to (try and) fix aircraft RADAR / Radio / Navigation / Flight Control System stuff.
    Likewise with the 'scope - as I mentioned, also agree on the meter, and a good ole 'moving coil' can give you a fair amount of info - certainly for measurements that fluctuate / pulse at a relatively slow rate.
    William, if you have a Fluke meter lying around then you're probably not going to need to buy another, my Fluke 89 iv has served me VERY well over the last 10+ years.
    The only time my training (and common sense) let me down was tracing excessive current draw through an old TO-3 transistor (enough to smoke and arc a 1 watt resistor carbon on a TV mainboard). I ignored (failed to read) the 'WARNING - CHASSIS LIVE REGARDLESS OF MAINS POLARITY' label, wet my fingertip with a bit of saliva and touched the top of the TO-3 to see if it was getting warm . . . . . . . .
    You can guess the rest, but it goes to prove that we never stop learning - or something like that . . . . . image
  • bprewit
    After a quick search .. the best online basic electronics course that I found is here.
    The "MOOC" courses (edx, coursera, etc) are typically undergraduate-level courses which are part of an electronics engineering curriculum.  While they're valuable if that's what you're after, they're certainly not "getting started with electronics".  I've been working on MITx - 6.002.1x from edx.org in my "copious" spare time, just as a review .. However, it's more "quantitive circuit analysis" than "hands-on" .. probably not a good place to get started.
  • uscdadnyc
    Try the site udemy.com. This IS a For-Profit Site whose courses run the gambit of Elementary-to-Sophisticated. Their Pricing Policy is Free Enterprise run amok.Depending on their (Udemy) internal economics one could pay one price one day and another price the next day. Drives my crazy, but then people call me crazy all the time. But I am not Stupid. I set a price that I would Pay and will take it when it hits that price. It is Like College & University Education here in the USA. They over-price their Tuition, then offer you Financial Aid
