Raspberry Pi Forum Pi 3 board failure?
  • Replies 12 replies
  • Subscribers 708 subscribers
  • Views 4048 views
  • power supply
  • rasberry pi 3
Pi 3 board failure?
sunnydale102
sunnydale102 over 9 years ago
I recently received a Pi 3 B. I've installed jessie and I've been running it without issues for a couple of weeks.
Last week I turned on the power and waited for the console output and saw nothing.
The red LED on the power supply monitor flashes, which I believe indicates that the power supply is low. After about 60 seconds or so of flashing the LED goes out. There is also some flashing on the green LED during this time.
I've probed PP35 on the 5V input and noted that the supply is indeed low, about 4.5, and declines until it drops below 3.5V at which point the red LED goes out. I've tried various alternate USB power supplies and all show identical results. No smoke, nothing feels unusually warm so there's no obvious fault.
Note that both the power supply and the SD card work as expected on my test Pi 1 B. I realize that the Pi 1 draws less current but it all worked fine for a couple of weeks.
Any suggestions?
"Sunny"
  • sunnydale102
    0 sunnydale102 over 9 years ago
    Gentlemen, get your fingers ready to wag at me.
    I have my Pi3B running just fine.
    The problem? A busted powered supply in my USB hub appears to be the problem. That's why things ran one day and not the next.
    A couple of key items lead me to this resolution.
    First, your encouragement and suggestions. Thank you both for your input!
    Here's how I (finally) got the picture.
    1. I monitored my Pi1B 5V and 3.3V supplies. I noticed that after my Pi3B failed that the Pi1B still appeared to run correctly. In fact, it was barely hanging on. The 5V supply varied so widely that even the 3.3V did not remain steady, but the processor would boot. When that became obvious all fingers pointed at my hub (OK, me too... I should have suspected the hub from the start).
    2. When I ran power into the I/O header, the Pi3B did not appear to boot as I was monitoring the console output, in fact it was running fine. I had missed the fact that the "lite" version of jessie does not default console output. Blame laziness on my part for sure but also habit. I've installed many, Unix & Linux servers during my last working years and always I would configure from the console.
    Thanks again to Roy for pointing out the configuration issue.
    I have gotten a better hub today with a 2A "fast charging" port and that's what I'm now using to power the Pi3B.
    So there you have it. Start wagging!
    Thanks again for your input and encouragement that's what made all the difference!
  • clem57
    0 clem57 over 9 years ago in reply to sunnydale102
    Always check/suspect the power supply first. If no tols like multimeter, get another power supply first that is new and reliable. Hopefuly others will learn from this blog.
    Clem
