Raspberry Pi Forum boot from ssd in pi desktop
  • Replies 73 replies
  • Answers 11 answers
  • Subscribers 712 subscribers
  • Views 13515 views
  • raspberry_pi_space
gdenicolas
gdenicolas over 9 years ago
I couldnt find the file pidesktop.deb. The webpage is really complicated.
  • cstanton
    0 cstanton over 9 years ago in reply to tuctboh
    I would suggest trying either the hard drive clone script that's included with the debian package to replicate your SDCard raspbian install, or try imaging the SSD by connecting it to another computer (this is outlined in the manual).
    Have you tried wiping the SSD and partitioning it via other ways (not imaging it) to see if it's compatible and working in with the Pi HAT add-on? There could be something funny going on there, too.
  • tuctboh
    0 tuctboh over 9 years ago in reply to cstanton
    Unfortunately, I can't. I don't own anything else that can take the mSata card (https://smile.amazon.com/gp/product/B00TGIVRYU ). The Pi-Desktop is the only thing.
    Tuc
  • cstanton
    Well, you don't need to connect the mSATA card into something else directly, you can plug it in via USB to another computer. This is covered in the user manual, as the SSD connects to the Pi in the Pi Desktop via USB, so to can it connect to another computer.
    0 balearicdynamics over 9 years ago in reply to cstanton
    When I bought the Kinston SSH I expressed chose a SATA storage as I was having in home a number of recovered SATA-to-USB external powered boards from old HDD external boxes. These was heavy small boards to power externally 5 inches HDD with 5V 2A power supplies. This was to have a larger storage on the Raspberry PI old versions and the multi boot bit never had been mentioned.
    I also published an article on how to boot from SD card but using the external USB SATA connected HDD with the entire file system on it. The blog post (from 2015) is here: Meditech: RPI master storage system with some image of the first experimental tests while the disk setup procedure is here: Raspberry PI: USB hard disk boot
    As I saw none of the mechanical HDD was powered correctly by the PI including the 2.5 HDD declared as self-powered by the USB connector. Also today I use a couple of 3TB Western Digital USB HDD that work properly only if directly connected to the computer USB; if I use a HUB for these disks I should use a powered USB HUB else stability problems in data transfer still occurs.
    Seeing that the concept was working I bought a very low power consumption SSD Sata from my local retailer and a Startech SATA to USB connector supoprting both USB3 (full speed) and USB 2 on Amazon (https://www.amazon.es/gp/product/B00HJZJI84/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 )
    Applying the settings mentioned above things worked fine. The PI was anyway booting from the SD card no longer stressed during the normal usage.
    Now with the introduction of the multi boot option settings in the PI3 things are working better and it was finally possible to remove the micro SD card.
    Just a note: as in terms of reliability an SSD is more durable than the SSD card thinking to make a device that should work for long time boxed (maybe to a client site) it is the worth to use this setup instead of the traditional one despite the advantage of a larger storage space for the file system with a cost of 50-60$
    Enrico
  • cstanton
    0 cstanton over 9 years ago in reply to balearicdynamics
    The Pi Desktop fully powers off if you hold the power button for 4 seconds, you can then power it back on by pressing the power button again.
  • tuctboh
    We might be misunderstanding each other. My card was a true mSATA, came with just the drive. No connectors/enclosures/etc. I connected to the hat, booted off SD, dd'd to the mSATA.
    So, I went on Amazon to get a connector. USB to SATA, then a card that converted SATA to mSATA. When I got it, I shut down the machine ready to take out the mSATA and put it into the adapter and run USB. I figured JUST for giggles I'd make sure one more time it didn't work. I already had the machine down, so I just pulled the SD card. Turned it on. Eventually got the 4 raspberrys, colorful screen, seemed to do that again, and finally booted Pixel. I shut down, restarted, and it seemed to be fine. Tried a few more times, worked. <SHRUG> Maybe I was too impatient the first time. But, the news is, I'm fine.
    Tuc
  • tomgeorge
    0 tomgeorge over 9 years ago in reply to tuctboh
    For the record I too connected a mSATA SSD to the hat, found it was sda,
    downloaded Raspbian to the Raspberry Pi, dd it to /dev/sda  then
    followed the Raspberry Pi: USB: Hard Disk Boot instructions. Worked like
    a charm. df -h now shows /dev/root 230G 16G 202G 8% /
  • slikk66
    0 slikk66 over 9 years ago
    Hi Just am trying to setup my pi desktop.
    Stuck an 8GB microSD in the pi, booted it, updated/upgraded, installed dpkg of pidesktop-base.deb, but when I run ppp-hdclone, it has no selectable options for source or dest.
    Source is blank, dest says "no items available"
    I have an adata msata 128GB drive connected.  Do I need to setup/format this drive first?  Any steps I'm missing?
  • tuctboh
    0 tuctboh over 9 years ago in reply to slikk66
    Whats the results of :
    ls -la /dev/sd*
  • slikk66
    0 slikk66 over 9 years ago in reply to tuctboh
    Thanks for replying!
    I just restarted the whole process over again, I continued to dig and think I got myself to a point where it's time to start over.
    I just reflashed the latest rasbian + pixel image, and it's currently going through the apt-get update/upgrade process.
    If I run your command, I get:
    pi@raspberrypi:~ $ ls -la /dev/sd*
    brw-rw---- 1 root disk 8, 0 Apr 10 10:09 /dev/sda
    brw-rw---- 1 root disk 8, 1 Apr 10 10:09 /dev/sda1
    I tried to install gparted as I read in another thread I would need to format the ssd first, but when running "sudo startx" it would give me an error about "agent already running" or similar, seemed like it couldn't run another graphical interface while I was already in one? Not sure about that.  Then I tried to run "parted" and gave it a gpt label, and tried to make a primary ext4 partition, but that didn't seem to do anything, so starting over.
    Any advice?
    Edit: bit more info about current status:
    pi@raspberrypi:~ $ df -h
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/root       7.2G  3.7G  3.3G  54% /
    devtmpfs        459M     0  459M   0% /dev
    tmpfs           463M     0  463M   0% /dev/shm
    tmpfs           463M   13M  451M   3% /run
    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
    tmpfs           463M     0  463M   0% /sys/fs/cgroup
    /dev/mmcblk0p1   41M   21M   21M  51% /boot
    tmpfs            93M     0   93M   0% /run/user/1000
    pi@raspberrypi:~ $ cat /etc/fstab
    proc            /proc           proc    defaults          0       0
    PARTUUID=038c4707-01  /boot           vfat    defaults          0       2
    PARTUUID=038c4707-02  /               ext4    defaults,noatime  0       1
    # a swapfile is not a swap partition, no line here
    #   use  dphys-swapfile swap[on|off]  for that
