Raspberry Pi Forum Pi Desktop : how to upgrade to new raspbian (buster)
  • Replies 18 replies
  • Subscribers 707 subscribers
  • Views 5564 views
  • rpi3 pi-desktop element14 stretch to buster driver boot
pcardona
pcardona over 6 years ago
Hi All,
I apologize my poor english. Maybe I don't say the facts with the right words.
Context :
My Raspberry Pi 3 is inside an Element14 Pi Desktop, with a Kingston SSD
Desktop Computer Kit for Raspberry Pi
This system i using the drivers to boot and shutdown :
https://www.element14.com/community/external-link.jspa?url=https%3A%2F%2Fgithub.com%2Fpi-desktop%2Fdeb-make%2Freleases
Bad experiment :
Once, I tried to upgrade to the newest raspian (Buster), but my upgraded system failed to boot, so I thought this was a limit due to the installed driver and I had to go back and I installed again the previous raspbian :
Raspbian GNU/Linux 9.11 (stretch).
My question :
So my question is how to upgrade the raspbian to Buster the right way, without trouble with this driver limit within the Pi Desktop. I would appreciate to know step by step how to do this without breaking again the boot process.
Thanks for your kind attention.
  • pcardona
    0 pcardona over 6 years ago in reply to pcardona
    Well, I forgot to unsinstall the pidesktop first, so I resolved the issue simply like this :
    1. Uninstall  first :
      sudo dpkg -r pidestop-base
    2. Install again and the job is done:
      sudo dpkg -i pidestop-base-1.1.0.deb
  • kmikemoo
    0 kmikemoo over 6 years ago in reply to pcardona
    pcardona  EXCELLENT!  Great job.  Also, welcome to the Element14 community.
  • colporteur
    0 colporteur over 6 years ago in reply to kmikemoo
    I'm no doubt not seeing the big picture. I have been frustrated in the past aligning with themed O/S to have the support team fracture. I tend to shy away from flavours that are not mainstream.
    So if you had one of these kits, I assume there is nothing that  prevents you from grabbing a Raspbian buster image from the .org repository and after completing an install adding the tweaks for the RTC and shutdown circuit?
  • kmikemoo
    0 kmikemoo over 6 years ago in reply to colporteur
    colporteur  You are spot on!  One could add these themselves or even create a script to do the install.  I like the idea of adding them myself because (to me) that's part of the magic of the Pi.  I'm not just adding application programs.  I'm adding functionality.  Okay, they might be the same thing, but not in my mind. image
  • pcardona
    0 pcardona over 6 years ago in reply to kmikemoo
    Hi Mike,
    I seems that the reboot process has changed between the Stretch and the Buster : the fact is that the pi-desktop package provided no more supports this functionnality. As I can understand, after a try to boot again, the system is shutting down, which is not the expected behaviour. Well, we do not need this functionnality all the time, but I like to understand why things stop to work.
    You said You wrote your own scripts to do this. Could You share your knowledge to help us to understand this process within Buster and the pi-desktop ?
  • kmikemoo
    pcardona Forgive me for being unclear.  I have not written a script.  There are folks in the Community that are smart enough to do this.  I am not one of them.
    I prefer to install the features one at a time.  I keep a notebook of the programs I like to add but - in truth - each SD card gets regularly reformatted and reflashed.  Only one of mi Pi's has a dedicated purpose.  It runs an MMDVM hotspot.  All of the others are subject to being reset to a fresh install of Raspbian.
  • perso00
    0 perso00 over 5 years ago in reply to pcardona
    Bonjour,
    J'étais dans la même situation mais après de longues recherches, j'ai trouvé une solution que je viens d'installer et qui semble fonctionner.
    L'éditeur Embest, avait sur son site un lien vers un github comportant un fichier pidesktop-base.deb version 1.1.7
    https://www.embest-tech.com/down.aspx?key=pi%20desktop
    https://github.com/hoopsurfer/pidesktop
    Voilà, en espérant que cela pourra vous aider
    Cordialement
    Patrick C.
  • schumi0815
    0 schumi0815 over 5 years ago in reply to colporteur
    I have RaspPi 3b+ / OS: Debian 10 Buster / the Pi Desktop-Kit dev-14354 and pidesktop-base 1.1.7 from here: https://github.com/hoopsurfer/pidesktop . Install is all good, but i haven't access to hwclock (Message: no usage hwclock found). why?
