Raspberry Pi Forum Insight why display fails with buffer board
  • Replies 24 replies
  • Answers 16 answers
  • Subscribers 705 subscribers
  • Views 6242 views
  • raspberry pi display
  • lcd display
  • spi data
colporteur
colporteur over 5 years ago
Can someone share their insight  into why no images are displayed on the LCD display when a buffer/level shifter board is inserted between the Pi and the display?
The project is to display images on a 1.3 inch display using a Raspberry Pi. Inspiration for the project came from Episode 465: Lego Raspberry Pi HQ Camera . I'm using the LCD screen Katie's  hifromkatie used in the project.
I can display images on the display https://github.com/pimoroni/st7789-python  connected directly to the Pi. Images are not displayed if I insert a buffer board between the Pi and the display. I have tried modules with TXS0108E and BSS138 chips and get the same results.
Attached is the pin out for connections. I confess I have limited experience with this communication protocol. I was hoping the buffer would provide some isolation for the Pi to enable me to move the display away from the Pi. I assumed a level shifter would not introduce issues but that does not appear to be the case.
Can you share any insight into what is causing the issue and possible solution.
Message was edited by: sean conway I added pictorials of the buffer/level shifting modules. The module on the left is is based on the TXS0108E chip and the right is a BSS138 fet based on an adafruit model https://www.adafruit.com/product/757
  • colporteur
    0 colporteur over 5 years ago in reply to nathandumont
    The suggestion of dropping the clock speed intrigues me. I'm using the python PIL (now Pillow) module to upload the images and https://github.com/pimoroni/st7789-python is the driver.   The objective is to simulate a roadside billboard sign for a model railroad, so I think I have some room to play with when it comes to speed of update. The true test would be what it looks like on display.
    To my knowledge, the clock speed doesn't appear to be a parameter. I will crack open the module to see if there are any hidden clues.
    Looking at details on SPI, I figured CS was the control line to call multiple external devices? I'm not sure if the PIL module can deal with this either. All part of my research to development.
    0 michaelkellett over 5 years ago in reply to colporteur
    In the examples in the git repo. you link there are lines in the setup code of each like:
    spi_speed_hz=80 * 1000 * 1000
    try changing it to
    spi_speed_hz = 20 * 1000 * 1000
  • colporteur
    0 colporteur over 5 years ago in reply to michaelkellett
    Hey great. Will do and report back. Thanks.
  • colporteur
    Your insight was the fix to lower the frequency. In addition the same area of configuration gave me the knowledge to alter the CS. I can now use both.
    I was still unable to use either level converters after lowering the frequency. I did test the display operation down to 50Khz. Slow on refresh but it worked. Still no success with a level converters at this frequency.
    I appreciate the frequency fix. At the slower speed the animation of the screen updating is rather cool.
