Raspberry Pi Forum RPi Model A or B?
  • Replies 11 replies
  • Subscribers 709 subscribers
  • Views 2269 views
RPi Model A or B?
Last year I purchased what I thought was a Model-A Raspberry Pi from Element-14/Newark (US). Since I later had a project that needed a Model-B, I bought one of those also, a few weeks ago.
Recently, I was checking out the differences between the two models and found that, according to various sources, The Model-B has 2 x USB ports (1 on the Model-A) and an Ethernet port (none on the Model-A) as well as a memory size difference.
Now my "Model-A" has both an Ethernet port and two USB ports so I'm confused. Is it, in fact a Model-B (which I didn't think was around when I bought the first one)? Is my information on the model differences wrong? I would appreciate it if someone could shed some light on this and clear up my confusion.
Also, what's the easiest way to check the amount of memory?
  • johnbeetem
    0 johnbeetem over 12 years ago in reply to charlesb255
    Charles Burnaford wrote:
    Just to let you know, the way you tell the difference between the 256meg and the 512meg is that the 512meg has mounting holes and the 256meg does not.
    This is true most of the time.  However, there were some Model B with rev 2.0 PC boards (with alignment holes) shipped with 256MB: see this thread chez RasPi: http://www.raspberrypi.org/phpBB3/viewtopic.php?f=63&t=48784
    Another way to tell your memory size is to look at the SDRAM chip, which is soldered on top of the SoC.  My original rev B has a Samsung K4P2G324ED.  The important part of the number is "2G32" which is 2Gi bit (256 MiB) by 32 bits wide.  A 512MiB Samsung SDRAM starts with "K4P4G32": 4Gi bit = 512 MiB.  I would expect Hynix memory numbers to be similar.  Memory chip manufacturers always quote sizes in bits, not bytes.  It's more impressive that way.
