Raspberry Pi Forum Wolfson audio card + Jasper ?
  • Replies 22 replies
  • Answers 2 answers
  • Subscribers 687 subscribers
  • Views 3472 views
  • wolfson
  • jasper
  • audio
  • alsa
  • voice
  • raspberrypi
  • raspeberry_pi_accessories
fvan
fvan over 11 years ago
has anyone been able to get Jasper (Jasper | Control everything with your voice ) to work with the Wolfson audio card ?
I tried getting it to work with two different approaches and ended up with the same result (which is something good I suppose).
  • Took the Wolfson image and manually installed Jasper software
  • Took the Jasper image and manually installed Wolfson drivers/kernel
Jasper is working via the command line, but when trying to use voice control, I get some (Alsa related?) errors.
Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2762
Expression 'r' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2013
Expression 'PaAlsaStreamComponent_FinishConfigure( &self->capture, hwParamsCapture, inParams, self->primeBuffers, realSr, inputLatency )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2650
Full log attached.
Thanks!
Frederick
jasper_log.txt.zip
  • malakai
    0 malakai over 11 years ago in reply to willondubs
    Thank you I think I am getting closer here's the error without the edits
    pi@raspberrypi ~ $ aplay /home/pi/jasper/static/audio/jasper.wav
    ALSA lib pcm_direct.c:1658:(snd1_pcm_direct_parse_open_conf) Unknown field the
    aplay: main:682: audio open error: Invalid argument
    OK it plays if I sudo
    Is that typical?
  • malakai
    0 malakai over 11 years ago in reply to malakai
    Thank you all.
    It's a hack but I just added sudo aplay to mic.py and boot.py image all is well in my world now.
  • fvan
    0 fvan over 11 years ago in reply to malakai
    Jasper starts up, asks how he can be of service and such, but when I try to give it a command, nothing happens image
    Edit: ok, I get the beep beep when I say Jasper, and it replies image (had to increase input volume for DMIC)
    But my english must be so bad that it never answers correctly when I ask the time ...
  • fvan
    0 fvan over 11 years ago in reply to fvan
    Ok, it just seems to have difficulties understanding me, but it works.
    If I repeat nice and slowly, it seems to work! Thanks everyone!
    Hey Frederick,
    I'm trying to get voice command by Steven Hickson to work with the Wolfson audio card. It seems like i'm having similar issues to what you experienced with Jasper. I currently can play music just fine through the pi, just when I try to set up voice command i am not able to get audio to output. I changed the .asoundrc file on the pi thinking it may be a similar issue but am still not getting any audio. I was wondering if you had and ideas of how I might be able to troubleshoot this problem.
    Ryan
  • fvan
    0 fvan over 11 years ago in reply to Former Member
    Hi Ryan,
    as you read here, I was struggling a lot to get Jasper to run with Wolfson also.
    I think the best approach would be to create a new discussion and have others participate there, as this will create the best visibility on your problem.
    Also try to attach log files/screenshots/anything that seems useful to help troubleshoot the problem.
    Frederick
    0 Former Member over 11 years ago in reply to fvan
    Frederick
    What did you do to get the Jasper + Wolfson working after you encountered all the error messages? I am encountering similar messages as to what you did, but am not having any luck resolving them. I'm getting the following:
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
    ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
    ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
    ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
    ALSA lib pcm_dsnoop.c:551:(snd_pcm_dsnoop_open) The dsnoop plugin supports only capture stream
    Drew
    0 Former Member over 11 years ago in reply to malakai
    For context to my previous post, I followed the RoadTestReview Todd put together. Todd, if you have any thoughts here they'd be appreciated as well.
  • fvan
    Hi Drew,
    have you gone through all the feedback from Todd and Will in this thread ?
    One of the last things I fixed was this: http://www.element14.com/community/message/118485/l/re-re-wolfson-audio-card-jasper#118485
    Frederick
    I've been over this post many times, and many others image. I did install libasound2-plugins. The other thing I'm realizing is that when I play the jasper.wav sound using aplay I get the 'Playing WAVE '.../jasper.wav' : Signed 16 bit...' message, but it never terminates and I don't hear anything. I have to ctrl-c to get it to stop.
