Raspberry Pi Forum what psu do I need?
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 710 subscribers
  • Views 1703 views
what psu do I need?
vinegreen
vinegreen over 11 years ago
I'm making an arcade machine. my screen takes 12v at 30 watts. I want it all to run off the wall, in aus we have 240v.
what power supply should I use?
  • rew
    0 rew over 11 years ago in reply to bodgy
    I'd say: Don't under-specify a powersupply. The problem with that is that it leads to "works most of the time" situations, and because "it works", you don't think about changing the powersupply.
    So, as john already said get a decent ATX powersupply. That will work. It provides both 12V and 5V.
    If you need something lighter/more compact, get a 3A+ 12V powersupply, and a step-down-converter for the 5V. You could consider getting an USB charger-module for in a car.
    If you get those cheap-from-china, they usually reach about 70% of their rated current. So for the 'pi go for at least 1A of rated current. (sometimes the western "quality" shops end up selling the doens't-meet-specs stuff as well...)
  • vinegreen
    0 vinegreen over 11 years ago in reply to rew
    Thanks again for the help
  • djd9617
    0 djd9617 over 11 years ago in reply to jw0752
    Keep in mind, power supplies are not designed to constantly run at their max rating. I generally prefer to calculate the max wattage I will require, and get a psu rated at 1.5 times that max wattage. Also, its always worth putting up a bit extra cash for a higher quality psu. Higher qualities tend to last longer, and if they do fail, they have less of a chance to damage whatever they're powering
  • rew
    0 rew over 11 years ago in reply to djd9617
    Keep in mind that whereas a raspberry pi is specified at 700mA Max, it will generally run at around 400mA :-)  (the B+ uses even less. Or let's say: similar numbers but lower).
